I can chime into the reduce cost thing. I know this cause I work for toyota. Cost reduction is a daily expectation. If you can think of an idea to reduce cost, the Co. will pay you for your idea.
7M-fanatic said:Here is my extended oil pan for the Cressida 7M.
The extensions are off the shelf from www.speedwaymotors.com.
The scraper is of my own design.
As is the swing baffle.
Not shown in the picture are extra, full length scavenging scrapers on the right side of the pan, to increase oil drain back, and drain channels behind them to allow oil from the main scraper a direct path to the sump.
This is going on a NA camed 7M that will be turning 8000+ RPM, so oil control was very important.
But it turned out so nice, I will also be putting one on my forced induction 7M.
williamb82 said:dude, thats nice. same pan i need for my mkii. how much oil do each of thos kickouts add?
