^^^ And that will give you 60-80 psi of pressure...make sure the rest of the oil system can handle it. For stock or light/medium mods, 5mm is plenty
Bummer I will fix it tonight.starscream5000 said:Your last link does not work for me. It's too bad you can't have the high pressure flow of the broken in oil squirter and the low pressure opening point of the new one all in one package...
It shouldn't make any difference at all...... :nono:mk3forme said:Interesting indeed. Im curious to see what my oil pressure will be like with your mod since I dont have squirters
Actually I meant what my oil pressure w/o squirters vs with and with the 5mm shim in the pump. I realize this mod is more for flow and not pressure increase.IJ. said:It shouldn't make any difference at all...... :nono:
arz said:+200K Vid link fixed, here it is again so you dont have to go back.
Video pressure test of +200,000 mile oil squirter
I would rather have six of those oil squirters than six new ones as this one seems to flow (based on the sound) starting around 10 psi and all the way to 80
