uh, hey guys help me!
tsuper92
supra addict
Apr 7, 2005
1,376
mass
take some pic's once the sheild is out and the urethane bed is trimmed down.i'm just curious how bad it is under the glass.sometime's the rust blister's so bad it stress crack's the glass.
NexiusEvaro
Car Noob
May 3, 2006
60
Blgs, Milky Way
hey jenny! n welcome!
while we are on the subject of rust...
i am in the prep stage of the na to turbo conversion and my heater hardpipes that run around the block were in pretty rough shape on the ends with corrosion. I'll post pics of before and after the clean up in a build thread at some point, but at this stage they are cleaned up and almost rust free.
I picked up some zinc marine use primer that is billed as self-sacrificing. As I understand it, the stuff binds with the metal and then protects it by giving itself up to corrosion. Seemed like a pretty cool idea to me but questionable and I was wondering if anyone has used this stuff to fight corrosion on the water hard pipes ends? Is this a Really bad idea? That pipe is $195 or something from toyota here in hicksville and no one around here want to try to bend me new ones.
Just curious
and yeah... girls get the hookup - guys, not so much =P
Disced
Pie + NYQuil = FTW
Edmonds, Wa
lol; just reading this thread makes me realize how much you all post wh0re.
I had rust just like that; and just sanded it down to bare metal. Primed, re-sanded, primed and did a little bondo.
Looks perfect.
mkiiSupraMan18
Needs a new username...
United States
NexiusEvaro said:
-whatever all that stuff said about corrosion on the ends...
It's just the ends, take them off, hit them with your bench grinder, put the hoses on and tighten them down. I pray that the day when people start pulling hoses to check for imperfections never comes... and if it does, I'm going to switch over to Scions :icon_bigg
