X-man said:I have no intentions on limiting myself to 700 rwhp. I'm already past 700 hp.
On a stock gasket too, wow! Go for 1500whp!
bigaaron said:On a stock gasket too, wow! Go for 1500whp!
dbsupra90 said:he never said he was on a stock gasket. a stock motor w/ mhg. all i was trying to do was insert my experiences. everyone ive mentioned are friends of mine and most of which ive worked on or had a hand in at some point. not random people i saw on the internet to try to make as an example. im done here. it seems at this point you are just going out of your way to be a prick. fine. we are nothing but some southern rednecks w/ "unconventional" thinking anyway.
Loki said:I ran my car at 14psi all last summer with a stock HG and bolts and never had any problems. When I pulled the head off it this past winter the HG looked great.
this is where the turbo/exhaust wrap, intake heat shields, along w/ intercooler spray kits of all kinds, composite intake mani. gaskets, and cold air intakes come into play... all of which i put on my car, so when i do run high boost on the ct :nono: it'll be at it's highest efficiency...Doward said:Detonation kills the gasket. Stock CT26 + elevated boost levels WILL increase your intake temps, and when you increase those temps far enough, you will start to detonate slightly... Will your old, worn out knock sensors pick it up?
Sure hope so.I'm going to run 12psi on a stock turbo/gasket, and then go AEM to tune it - the intake temps and exhaust temps will tell the story
bigaaron said:I'm being a prick? I try to speak out to caution people about urging others to run high boost on a stock headgasket, and I'm a prick? I tried to explain that people making big power on stock headgaskets has happened, but much more often people experience headgasket problems and a metal headgasket is a good idea. Then a gang of people say how much hp they made and how much abuse their stock headgasket took, somehow implying that I don't know what I am talking about and a mhg is a waste of time and money. So rather then personal attacks, I got a little sarcastic, but don't call me a prick bro. This thread was about the limits of the stock hg, what does making 700whp with a mhg have to do with that? And I didn't call anyone a redneck, I don't even know you. I'm not holding anyone back. I'm just trying to get people to make good educated decisions about what is a good idea to do with their engine. I think the people I was intending to target will get the idea. Plus, I'm white and I like rednecks. I have some in my family actually.
I honestly don't understand the logic. Here's an example:
You want to go 149mph. Plenty of people have driven 160mph on 149mph rated tires and they didn't blow. Does that mean it's a good idea?
NO. Is buying 200mph rated tires a waste of money even if you may never drive that fast? Probably not. I am the type who would buy 200mph rated tires to go 160mph. That's just me, but I would urge others to do the same. And if you urged others to do otherwise I would speak out against you. It's nothing personal.
X-man said:...but neither did you using this thread as another opportunity to sell parts, see page 2.
Forget elevated boost level, the wrong kind (or not enough) coolant can kill the stock headgasket on stock boost alone.X-man said:You come off in these statements you make that elevated boost levels will blow the stock headgasket end of story.
mattjk said:wow, this is worse than 1jz vs. 7m
For every one good head gasket story, I've seen 500 bad ones.
Doward said:Bigaaron, I'll take you up on that offerShipping to 32641
