The wastegate hole has been ported to eliminate the boost creep problem these turbos have, and it is fixed. This turbo has between 2000-2500 miles on it.
Opened the ID of the hole up to 1 inch and problem solved!!!
GrimJack;1008646 said:Well, it was a nice theory. Go spray down your hand with burn spray...
Boost Lee;1008673 said:Oh gawly this thread has an assload full of suggestions.
Flapper door AFMs, Oh yes. Do it. :biglaugh:
Armando - Only running in a dark room with a blindfold,
But you should pull the 4" exhaust we fabbed up for you, and try a 3" or even open downpipe and see how she behaves.
Scientifically speaking, I don't think this would solve the problem...But the problem did begin after the 4" install.
How much longer are you going to be out at the "shop", A? :biglaugh:
Maybe I'll swing by...
GrimJack;1008670 said:I am really starting to wonder if you are actually outflowing the Lexus AFM. I'd love to have some way to measure how much power you're putting down before hitting fuel cut.
As I recall, previously this turbo was matched up to a standalone, so fuel cut could be tuned out. Same here, I'm running a MAFT Pro.
The completely open wastegate test might rule this out - if you are still hitting fuel cut with the wastegate open, there is something rotten in Denmark.
Boost Lee;1008673 said:But you should pull the 4" exhaust we fabbed up for you, and try a 3" or even open downpipe and see how she behaves.
ArmandoP;1008709 said:[moral of the story... turbonetics backhousings and wastegates suck. tell me if Im wrong.
