ArmandoP;1007673 said:just ran with the stock AFM, and it spools alot slower and hits fuel cut at 8psi. so its not that.
Also, its worth noting that this car has run rich ever since I removed the emissions equipment long before I had fuelcut issues.
How did you eventually solve the problem on your setup?
I went standalone.:naughty:
I ended up throwing 2grand at the problem. No boost cut now though, and is better then ever.
My only other thought is that you have so many mods that your ecu can't handle it in its stock form so it fights back with boost cut trying to save your engine. You are trying to tune with an adjustment screw when you should be tuning with an electronic manipulator at this stage. The other problem is you don't have enough info to diagnose the problem. You really don't know what your true Hz signal is that your ecu is seeing, If you had a fuel computer of some sort you could log a/f ratio and boost pressure right up to when you hit boost cut and then know what is really happening. Since you have 580cc injectors you should have no problem hitting 25psi without boost cut. I know you don't want to throw a grand at a twelve doller problem but there is something to be said for spending countless hours banging your head against a wall.
One last cheap trick, have you tried spraing carb cleaner around your intake mani to check for leaks at idle?
Good luck
