MassSupra89 said:I've got a Snap-On beam type and Craftsman click type. Nothing but good experiances. Very accurate.
bowsercake said:Craftsmen is nice because it's really easy to replace and, if you can break it into enough pieces you might even be able to get two replacements.
bowsercake said:snap on makes good tools. Craftsmen is nice because it's really easy to replace and most everything is always in stock. I don't hesitate to bash and bang my craftsmen tools because I know that I can always replace it, and, if you can break it into enough pieces you might even be able to get two replacements.
Clied said:I get 50% off on all Snap On tools at my school. But their tools are still hella expensive!!!
I just buy the cheap made in taiwan stuff.
shepfly said:Mechanical TQ wrenches (click,dial, or beam type) are basically a good guess at what torque you have applied. They are plus or minus 10% when certified by an accredited lab, then you add operator error to the equation, so what have you got? I would suggest you buy the best one you can afford,read the manual, and have a rebuilder show you how to get repeatable results. What you want is even clamping force on every fastner on your assembly. A transducer torque wrench is presently the most accurate hand method of achieving this. They should be 2-5% under lab conditions.
Poodles said:yes, but something that accurate is not necessary for 99% of the people out there...
aerospace industry would require such precision though...
