Top Speed
Projectmk3
1988 hard top N\A
Jun 20, 2007
Ontario
from what ive heard, you spedo isnt accurate after 100mph or something like that...mines never accurate cause i have aftermarket gages on my 88 and it tell me i can go up 2 160 <(laughs)
8,893
The speedo in the US is only required to be within 7%, plus or minus. And they are built optimitic, to slow you down. So if it is 5% fast, 5% of 60 mph is not nearly as much of an error as 5% of 125mph.
7MA61
7MA61
Aug 27, 2006
98
Sydney
Nick M said:
Elevation? Tune/age? A proper 7MGE W58 Supra will do 130, but not much more. 150 is impossible without a gearing change, and then more power.
164mph is possible with a 3.9:1 rear end and a W58. (limiter at 7000rpm), stock 7mge limiter is 6900rpm or mine was when I had a stock ecu.:icon_bigg
So 160mph isn't out of the question assuming a very long down hill road
ValgeKotkas
2,224
Over the pond
7MA61 said:
Not on mine used to crack 106-108kmph in second, now does 111kmph with the 7000rpm limit.
That was a manual MA70 ecu.
I think your car was once stock too :D But not anymore, when you thought it was:icon_razz
8,893
Like I said, with out a gearing change. And dream on if you think a 7MGE in an MA70 model is going to do 160 mph with any gear set.
I did the math once before. 6750 fuel cut is about 142 with a W58 and stock 4.30 gear. I think.
f00g00
586
Kuwait
I go flat out in mine a few times a week and I can barely get it past 5000 rpm in 5th. Ive got a run of about 5K to the base where I work after I go through a secure monitered area and I agree that the NA doesn't have enough balls. Ive had mine for about 10 years, been through 3 motors 2 transmissions and one LSD(which turned out to not be bad after all).
Ive only modified intake and exhaust which helped a little.
AGlobalThreat
Acceleration
Apr 4, 2005
991
Santa Clarita
The top speed with a redline of 6500, 4.30 gearing, W58, and stock size wheels and tires is 152.8 mph. Jeff Gore did the math for me a while back.
