Okay I'm abreviating this ALOT.
I have a fresh rebuilt engine.
550 ccs
MAFT PRO running speed density
big T4 turbo (I don't think specs are important)
T4 tubular exhuast
HK$ wastegate dumped into downpipe
4" filter/intake pipe (NO BUNGS)
stock intake manifold
AFPR
issue:
So i got a good tune on my car. could kinda keep a steady Idle around 400-600
drove around. cruising i'm seeing 14.1 AFR, under boost 12ish
idle around 15
During my build I put on NA valve covers to clean up the engine bay to go w/ my COP ignition setup and had plans to run a FFIM. well my funds ran low and I didn't get the FFIM so wh en I bolted it all up the throttle linkage runs RIGHT OVER the Valvecover ports that I had tapped w/ -10 AN fittings that i was goign to run SS lines for a CC setup. SOO.. i've been running w/ both of thoses ports open w/ 2 small filters kinda... Rigged ontop of them There's no pre-turbo port because of the upgraded intake pipe (the port that the PCV system ran to on the accordian hose) Well after I got my tune I was under the hood and realized that I totally forgot about the port on the TB that the PCV system went to. So i figured i'd cap it.. NOW the car runs like ass. My logic. I figured I tuned the car w/ that extra air comming in. so I tried tuning a little leaner. for the life of me I can't get it stable yet.. I've DUG all over these boards regarding the PCV sytem and I'm pretty sure I understand how the system works.
So stock... the TB port was actually brining AIR into the sytem from the Filter.. correct? so theoretically I'd want to leave that port Open right? as at idle w/ the TB closed that air is still coming into the engine across the valve cover ports. (of course brining the valve gases w/ it) so my reasoning is I should UNCAP it.
so c urrently i'm thinking of taking another filter and popping that onto the port, would that be okay?
also. the two valve cover ports. am I hurting my engine leaving them open?
do I need vacuum on those ports for crank case pressure? I'm pretty sure I've seen a couple setups similar w/ 2 filters on them as well (of course this doesn't mean its right either)
Any input from some of the more techincally informed would greatly help out thanks guys.
550 ccs
T4 tubular exhuast
AFPR
issue:
idle around 15
