Well.. NOw i've got another problem. I'm wondering if this is PCV related.
Now i've got my PCV system installed correctly w/ a CC and a one way check valve. I got a good tune on it. Idle was smooth. tip-in/out was a clean transition. and AFRs held at 14.4. SO I took the car for a drive. was running GREAT!!! drove about 5 miles, to get a feel. So i found a nice road and did a quick pull.
I got to 2nd gear w/ about 8 PSI and and started smoking crazy!!! I got home and I've got a line of oil across the top of the hood above the timing cover. oil all over my belts fan radiator and everything else in that vicinity.
Easily guessing a seal blew, I did the oil pump and main and I know i put FIPG around each seal to make sure they would stay. so I don't know which it is yet.
The question is WHY would I blow a seal w/ a "Good PCV" system when I did not have this issue w/o a PCV system installed before? THIS really bothers me, I'd hate to fix the seals just to have this again. I checked my One way valves.. the one comming off the TB port is set to allow air to flow TO the throttle body but not OUT of the throttle body (preventing boost from entering the PCV system) and the only other valve I could find. not relevant was the Master break cylinders and thats plumbed correctly as well.
INPUT greatly requested before I tear into this. Thanks guys.
