Update *aug 22 2007*
Update *aug 28 2007*
Update *aug 29 2007*
Update *sep 10 2007*
Update *Jan 8 2008*
Stage 1
r154 $350 parts car
r154 driveshaft $90 supramania.com
1jz r154 bellhousing $350 driftmotion.com
1jz r154 flywheel $269.99 driftmotion.com
ARP flywheel bolts $31.50 driftmotion.com
t4 turbo manifold $100 ebay
2jzgte from an aristo $2100
1jz oil pressure gauge sender adaptor $20 driftmotion.com
used driver side front fender $20 parts car
used front mudflaps? (old ones rusty, used ones like new) $20 parts car
coin tray in place of TEMS buttons
(Yeehaw found it!) $free parts car
used door lock cover (inside, the one with the shitty clips to the door, have to figure out how to make them stay on...) $free
1jzgte (supra) upper oil pan $150 for everything supramania.com
1jzgte (supra) lower oil pan
1jzgte oil baffle
1jzgte oil pickup
2jzgte oil pickup gasket $8 toyota dealer
2jzgte thermostat from toyota + gasket $too much. 27$ toyota dealer
used interior trim piece for center (around deck holds cig lighter etc) $10 parts car
**earls clutch line $20 supramania.com
**toyota oem clutch hardline turbo long $dont remember toyotapartscheap.com
**toyota oem clutch hardline turbo short $dont remember toyotapartscheap.com
**bought a full clutch line from driftmotion.com for about 45$ ... sick of the hardlines =/ heh
new Clutch master cylinder $40 toyotapartscheap.com
new slave master cylinder $58 toyotapartscheap.com
Manual transmission pedal set (clutch, brake) $25 i think supramania.com
new 2jz starter (ive actually had this since i owned my mkiv i just never put it in) $dont remember toyota dealer about 6 years ago
used hood bumpers on front (they look better than a blue hose holding it) $free parts car
walbro fuel pump (255 lph) $98 driftmotion.com
new pleather shift boot $15? supramania.com vender
shift knob 65$- i bought this from another vender here its a MOMO and it looks sweet.
marlin crawler shifter seat $10 marlincrawler.com
marlin crawler socket $8 marlincrawler.com
BIC solid motor mounts for 89+ mounts for a jz engine
$185? BICperformance.com
speedo cable for r154 (not actually sure if i needed this but it was free so who cares hah!) parts car
RP gear oil ( i actually bought this for my lexus' differential but never used it) napa
power steering fluid (ATF) autozone
toyota red coolant (this stuff is pricey) local toyota dealer
2jzgte water pump (oem) $129.30 toyotapartscheap.com
2jzgte rear main seal (oem) $30.36 toyotapartscheap.com
lower radiator hose $11.02 toyotapartscheap.com
wastegate $120 shipped from driftmotion.com
Oil filter relocation kit $60 ish summitracing.com
oil thermostat 40$ summitracing.com
k&n oil filter $9
2jzgte timing belt (gates) $75 titanmotorsports.com
charcoal canister $40 supraforums.com
oil pan gasket material Loctite brand $9 for a big ass tube summitracing.com
o2 sensor bung for new downpipe $24 bicperformance.com
oil cooler 61$ summitracing
intake pipe 15$ ebay
air filter k&n 54$ summitracing
MKIV supra throttle cable $65 driftmotion.com
2jzgte serpentine belt (power enterprise) $90 Titanmotorsports.com (ships out to me this monday)
some iridium spark plugs 45$ NGK from a local parts store
wiring harness $800 yikes thats pricey! but its OEM quality
they dont have those for 2jz aristo engines in mkiii LOL. Dr. Tweak @ pheonixtuning.com he'll hook you up.
oil pressure sender from a 7mgte=$free
water pump pulley = Bought the aluminm set from driftmotion.com 60$ same size as OEM
Intercooler hard pipes 160$ from driftmotion for everything i'll ever need hah.
2jzgte high pressure power steering hose from an mkiv supra. This was 55$ from a parts store... beats over 300 from toyota!
banjo for brake booster on 2jzgte intake manifold with fitting about 20$ for everything from toyotapartscheap.com
r154 inspection covers and gaskets 120$ for both new from toyotapartscheap.com
Turbo!!! i bought one! Turbonetics 62-1 dual ball bearing from treadstoneperformance.com
downpipe for turbo didnt buy it but i know i am going to buy a 90 deg bend of stainless steel to weld to a vband and on the 90 deg going to weld on my o2 areas so i can at least drive it without a CE light sometime and fogure out the o2 wiring. going to get this from treadstone as well welding done locally
Intercooler!!! i got a different one (the 1JZ one from Driftmotion)
HKS 40mm wastegate 403$ from mvpmotorsports.com
AEM uego 205$ mvpmotorsports.com
2jzgte mech fan clutch and blade - 258$ toyotapartscheap.com
Turbo Heat Blankie 150$ titanmotorsports
Oil lines for my turbo 115$
FPR suprasport 150$
fuel management - MAP ECU 2 baby
oil lines for t4 turbo - Treadstone 115$
Clutch suprasport.com $538.83
fpr bracket 15$ suprasport.com
Lipp upgraded ground kit 27$ suprasport.com
15$ for an extra ground cable for lipp
oil pressure sensor + plug pieces supramania.com 20$
FPR kit driftmotion 204$
vac lines + fittings 61$ suprasport
Stage 2
Coil Allen bolts(twins turbo) 15$
Second blow off valve - Synchronic Purchased 200$something
Injectors.
fuel pump install
Hook up and tune on my Map Ecu 2.
Sandwich adaptor for oil relocation
EGT gauge
install my clutch
BIC poly mounts
driveshaft 350$
the other two things empera makes i need to get up on since mine are thrashed
my crankcase hoses between valve covers
new alternator (mine was tested fine, problem solved)
larger a/r turbine housing - Purchased 235$
Update *Jan 8 2008*
Stage 1
r154 $350 parts car
1jzgte oil baffle
1jzgte oil pickup
k&n oil filter $9
FPR suprasport 150$
Stage 2
Injectors.
fuel pump install
EGT gauge
install my clutch
BIC poly mounts
driveshaft 350$
Syris;990321 said:More people need to understand this....4rth gear is direct drive on a 5spd and is 1:1 and will give true results which is where is should be dynoed, now on a 4spd automatic it should be dynoed in 3rd which is technically direct drive as in auto's 4rth is overdrive.
