bam! as you can tell thats new on the tranny and i changed the seal as well.
this is why some 2jz's cant use the driftmotion P/S line
clearance issues.... im just not going to bolt it on. the top is from my 7m's compressor.. im going to have to remove the p/s pump to bolt my a/c lines in. or im going to take off the compressor and bolt in the lines right before i install the engien but i will have to muscle it on there again... i might just do the power steering option.
clearance from the oil pressure line. driftmotion adaptor should work
no more boost tank. my new starter installed. aristo low oil level sensor the 1jz's plug was different. and because of the rear sump pan the dipstick sits funky.. and im sure even if i got a 1jz dipstick thing it would sit funky too.. oh well. and i'll get a new inspection cover in the mail soon...
89+ BIC bracket with 89+ BIC solid mount. oil bypass pictures as well. if you look closely you can see the support bracket for the intake manifold has no home now
![Frown :( :(](data:image/gif;base64,R0lGODlhAQABAIAAAAAAAP///yH5BAEAAAAALAAAAAABAAEAAAIBRAA7)
going to have to weld that to the mount or something~
major probs atm is getting the crank pulley off... maybe now that the transmission is on i can do that so i can change the front seal, timing belt, water pump, and throw on my access belt and new aluminum pulley on the water pump
Edit: i wanted to point out that someone mentioned the automatic bolts are too long for the manual transmission bellhousing. they are not so dont think you need to buy a set of new bolts...
they are pretty new
