i changed my rotted out factory exhaust with a 2 1/2 cat back system with a flowmaster. now every 2-3 days the part above the tail pipe is black with carbon. is there any thing i can do to fix this?
thanks,
thanks,
89nasupra;1096349 said:i got it with a blown head gasket, took the ebay route and replaced it again 4 months later. now that i got a felpro set with ARP's @ 85 ft lbs. the plugs were fine when i took it down the second time. the O2 sensor on the other hand pluged or un pluged doesn't make a difference. but i have no check engine light and in my opioion the car runs fine but this is my first supra so to some of you it might run like crap. i was hoping to meet some guys from my area that could maybe tell me if it runs ok for what it is.
89nasupra;1096600 said:i'll try to get some picks up but i can tell you now is 4-5 inches from the end of the bumper under the car. second it has 232,000 miles on it i have to put like a quart every 2-3 weeks i don't drive it hard being it has alot of miles and it's a n/a, i mean a stock civic si can kick my ass...lol the plugs look good, they aren't black or filed out looking none of them are wet of gunked up like it's burning oil in that cylinder. i may just be worring about something that is normal but was wondering. i may change the O2 sensor for the hell of it. the check engine light works, it comes on when i start the car then goes off.
89nasupra;1096652 said:no smoke when i start it, i just had the head reworked a few months ago (April) had new seals put in and milled when going whit the new gasket on round 2. i say a quart that offen, i checked it 2 weeks ago and the last time i did was in may. so i guess it's not really that bad. the cylinder walls were ok to the touch i could only fell some groves in number 2 cylinder. but it still has an ass load of miles. i cleaned out the cam covers when i had them off taking all the carbon that was in the baffles where teh pvc goes through. all that as far as i can tell is working good.
