go tell those guys on the other forum they are NOOBS. They wouldnt happen to have big "H"'s on their hoods and wings on the back of their front wheel drive cars would they? :nono: The turbo has nothing to do with it. All an AFC does is trick the stock ECU by changing the signal coming from the AFM. The ECU responds by adjusting the fuel accordingly (less or more based on the tricked signal). This can be done +/- 50% at any number of points in the RPM range.
That being said Im NOT suggesting you "fix" your problem using one. First off you need a wideband to properly tune it, and secondly it may be a bandaid approach if your rich condition is due to something needing repair (ie FPR out of whack, leaky injectors, resistance in the AFM signal line etc. weak spark, etc.).
For all you know you may just need some tune up parts, OR a complete rebuild. Im not inclined to speculate from here.
