drilled the new oil dipstick hole and plugged the old one! it's a little messy internally but I am very happy with the job done. I think it's a thorough one.
since I have never seen this actually posted...I thought I'd post some step by step pictures.
first, get yourself a 13/32" drill bit. You'll need to use some smaller bits first so the large bit doesn't walk... drill the front boss on the block, like this:
once drilled, it should look like this from the bottom. you can see the boss for the old one too, this needs to be plugged.
now comes the big dilema on how to plug this old hole up. There are tons of ways to do this, some use gasket maker, a bolt that's too small, a large screw, the old dipstick, loctite or JB weld....and any combination of these things.
Looking at my tap and die set, it turns out this 13/32s size is the size for an M12 x 1.75 bolt to fit in, once it's tapped. So I decided I would use JB weld and tap the hole for a suitable bolt!
I first grabbed a hex head, which will work but I found an allen bolt that I opted for in the end.
once tapped, I threaded the bolt in from the inside of the block and counted the threads that needed to be cut. I cut off two more than it would required to make it flush, so I could fill the depression with JB weld aswell, to ensure not leaks, while spreading it to help lock the bolt..
test fitting, it looks like this.
I then mixed up some JB weld (the origonal stuff...JB kwik sucks) and applied it to the tapped hole and the bolt. Once tightened I added more around the bolt and then on the exposed (block) side.
It's a little messy, I know...but it should do the trick very well. I filled the void behind the bolt with JB weld aswell, to help lock the bolt.
It's still wet in this pic I and haven't smoothed it, just applied it.
I then filled the depression on the exterior side to complete the seal, make it look attractive (once painted) and help lock the bolt yet again.
This is the most permanent fix for the hole that I can think of, outside of welding (which is a bitch on cast iron...) considering there is no pressure applied to this and the other sketch jobs people get away with...I think this will work great!
with this out of the way, I can finally paint the block tomorrow! I'm going to pick up the bottom end parts so I can get a start on assembly this weekend!
