And yet again....a BEAST has risen upon the land....people, ladies, gentlemen, my Supra is back online and running damn better than ever before!! I assure you....a savage has risen here today and when it is all said and done...."the people" will know my name....for it be, the true one....S-U-P-R-A.
Alright, so basically, I came home from work around 2pm Wednesday and got working on my Supra around 3pm. I went STRAIGHT through the night (no break, no sleep, no food) all the way till Thursday 5pm when I finally started it up; I drank water twice and took a leak once, that's it....other than that, I went STRAIGHT through, no breaks. I pulled the EFI fuse, cranked it for 10-15 seconds to build up oil and fuel pressure then started it up. However, I have a few kinks to work out; was leaking fuel from the seating area for the injectors inside the head, crazy vacuum leak (afr reading are off the chart lean) and was idling very high (however, that was just my throttle cable needing adjustments). So far, all thats left to do is find this vacuum leak which is pretty bad cause I can't even build boost above 4psi; simply won't hold. Another guy in the SAE club on my school campus just picked up a 87' Supra Turbo 7mgte w/ the Lex/550 mod and he said he was running lean at idle and WOT too; he said it was because of the "un-metered" air that passes through lexus Afm housing that cause our 7Ms to run lean sometimes. Its a lower/smaller section thats slightly bigger than the stock 7M's afm. So since we're engineering students and have access to a machine shop, he drilled (lathe)/machined up a screw fitment insert that blocks off that un-metered air section and now he's not running lean anymore. Anyway, my issue is a vacuum leak for sure and just can't seem to find it. I'm not sure if I'll let him mod my lexus afm like that just yet. First, I'm going to replace the hard/slightly cracked vacuum valve cover hoses and see if that makes any difference before doing that mod my lexus afm.
Alright, so I've installed a DM CT2657trim turbo, DM intercooler kit that comes with the HKS ssqv (replica/fake), Lex/550s, AFPR, Gates timing belt along with new tensioner and an MTX oil pressure gauge (that I haven't wired up yet cause I know NOTHING about wiring life). I'll be doing the 255lph Walbro either today or....who knows. I have final exams coming up and need to start studying. Anyway, here's a few pics:
Out with the old (blown turbo)
In with the new, savage'd one (57trim ct26 turbo)
I have only water in the radiator and block right now; wanted to do a coolant flush yesterday (Thusday) when I started it up but was too tired to do it (pretty much feeling numb after being awake and working on the car for 40+hrs and 24+hrs, respectively; and I only got 2hrs of sleep going into Wedneday morning)....I was like a man possessed working in my garage all those hours straight. I'm flushing the coolant today though.
Also, I threw in some synthetic cheapo 5w-30 oil from a dollar store around the corner. I'm thinking to change the oil today; should I throw in one more round of cheapo oil or is it too early?? Or can I throw in my "real/good" synthetic Castrol 5w-40 and K&N oil filter now?? I don't want to leave this cheap oil in the engine for too long though...
Don't worry, the HKS ssqv is now installed. I just didn't have a snap/c-ring pliers to install it until I got to the SAE club's garage and used a locking snap/c-ring pliers to install the BOV. I'll take some more pics later today.
