I was driving my car for 4 months with a blown 2nd turbo on my twins:cry:
I was gathering all the necessary parts and all the 'I wanna have' performance
parts.:biglaugh:
As some people know I was running my 2jz mk3 BPU'd for about 2 years.
Here's a picture of my engine bay with the stock 2jzgte:
There is a build thread of mine on the JZ motors section.
And since I already have:
# Low milage jdm aristo motor (perfect compresion)
# Healthy R154 trans & LSD differential with cooler (euro spec only)
# ACT heavyduty street single disc & JUN flywheel with SS braided clutch line
# Big 80mm exhaust (no cats),80mm Blitz cat back with 120mm endpipe
# Big IC (3" x 12.5' x 25" core) with 3' inlet and outlet
# Big 10 row oil cooler with relocation kit
# ALL the electonic 'goods' (Defi gauges,AVC-R,Blitz TT,AEM Wideband,etc.)
# Almost new (15K miles) tokico shocks and Eibach pro kit springs
# Suspension tune up with strut bars and waiting for sway bars and for D1
middle section brace bar.
# Big front JDM brake kit (14" 6 pot) with new rear rotor and rebuilt caliper
And many other parts that will support BIG power handling and performance
driving.
So,time to go Single :biglaugh::love:
Parts I need :
- Turbo kit (Turbo,manifold,wastegate,DP & midpipe,intake,SS lines & hoses
bolts - studs,T4 gasket,heat insulators,turbo heat shield,new oem gaskets)
- Fuel kit (fuel rail,big injectors,AFP regulator,SS braided fuel lines,fuel pumps
fuel filter, 'Y' block, AN fittings)
- Engine head tune up with some good performance parts (cams,cam gears,
lightweight underdrive pulleys,valve springs and retainers,new oem gaskets)
- EMS (performance standalone ecu)
Turbo kit choise:
I had in mind something big but also very responsive and fast spooling,with full boost at about 4000-4200 rpms :sarcasm:
This would have been my choise of turbo kits: PHR Stage 3 - GT72 DBB turbo
But,unfortunately this kit is oriented for mk4 by Powerhouse racing:cry:
So,parts like down pipe,mid pipe,intercooler pipe,intake pipe,screamer pipe
wouldn't bolt on a mk3 MA70 chassis.Parts of about $2000 USD should have
been modified to fit. So a turbo kit like PHR Stage 3 costs about $7000 USD
to reach my country.
Then I started purchasing individual parts...manifold,turbo,wastegate,etc.,
Turbo: ITS 72mm,T4 divided,DBB - water cooled with 0.70 A/R on hot side
Exh.manifold: HKS GT T4 divided ceramic coated (used part from a member)
Wastegate: HKS GTII 60mm wastegate
Intake kit: Greddy Air Inx kit
More picts coming...
parts.:biglaugh:
![p1430476_1.jpg](https://www.supramania.com/images/pb_archive/p1430476_1.jpg)
driving.
Parts I need :
Turbo kit choise:
![p1430476_2.jpg](https://www.supramania.com/images/pb_archive/p1430476_2.jpg)
![p1430476_3.jpg](https://www.supramania.com/images/pb_archive/p1430476_3.jpg)
![p1430476_4.jpg](https://www.supramania.com/images/pb_archive/p1430476_4.jpg)
![p1430476_5.jpg](https://www.supramania.com/images/pb_archive/p1430476_5.jpg)
![p1430476_6.jpg](https://www.supramania.com/images/pb_archive/p1430476_6.jpg)
![p1430476_7.jpg](https://www.supramania.com/images/pb_archive/p1430476_7.jpg)
![p1430476_8.jpg](https://www.supramania.com/images/pb_archive/p1430476_8.jpg)
![p1430476_9.jpg](https://www.supramania.com/images/pb_archive/p1430476_9.jpg)
