IJ.;1888204 said:Didn't know they were 2 bolters, thanks for that![]()
If they cast it from the same mix as 7M's I'd agree it's some of the hardest cast iron I've ever machined!PureDrifter;1888219 said:no problem, rumor is that Toyota didnt feel they needed the 6-bolt main for the 2UZ since it's an extra-dense (cite) iron block. the 1UZ was originally codeveloped to serve dual purpose as a base for a saloon car engine hence the over-square, short stroke, 6-bolt main, etc...
EDIT: Also, redrocco, it's documented that standard late model (98+) heads flow better than even ported+polished (though idk about OS valves) early heads. You can swap the later heads and intakes on though if you are willing to go standalone w/proper pistons.
That would have been pretty awesome...IJ.;1888444 said:After pulling my 7M I looked into a 1GZ for "Different" Sake![]()
If you are serious about upgrading the heads on your 1UZ to the later model heads, I would recco you take a look at fitting early (non-VVTi) 2UZ heads instead of 1/3UZ VVTi heads. You'll still have to go standalone (since there's no provision for distributors iirc) but you'll be able to use normal cams, which are a hell of a lot easier to find (kelford for example) than VVTi cams (for which nobody makes blanks...). You could use the 2UZ non-VVTi heads with the 1/3UZ VVTi intake manifolds since they clear a lot better in cars than the long runner truck intake manis do. (i'd stick to '1UZ since the wiring will be slightly easier).redrocco;1888454 said:I forgot to to add the flywheel into my list of swap parts. I got a pair of them (i think they were the first 2 he finished) for only $200 from suprarunner back in 07 because I helped him with the R&D and provided him with all the bolt patterns for the W58and R154 supra pressure plates.
I have thought about the head swap as I am running full stand alone at this point but the cost of pistons and ARP hardware and MLS gaskets has kept me from doing it since I plan to replace the 1UZ in my black supra with the 1GZ that I got in February. The 1UZ is going to be moved into my blue mk3 supra and put back to NA for the moment so I am trying to not spend any more money on it then i really have to. In the future once I get the 1GZ all set and running the way I want I will go back and see what more I can do to my 1UZ. I will have to compare the flow of stock 98+ heads to early heads with kelford cams and see what gets the most for the money.
SuperRunner;1888615 said:Stay away from the 2UZ, just don't even go there.
2UZ with 1UZ heads.....Better, but you are going to suffocate that displacement, but at least you will be able to rev. Stock 2UZ cams are not ment for rev's.
2UZ's blocks break around the 800hp mark
My recommendation would be any good old 95-older 1UZ. Stock cams aren't as bad as people may think, and the heads don't flow that bad. Question for some of you guys out there dogging on the 1UZ. Have you actually ever FLOWED a 1UZ head? My guess would be NO!!! Another question, have any of you actually ever boosted a stock motor? Only a few out there can say yes. A lot of crap gets thrown around on these forums.
A few facts:
1UZ heads flow just as good as 2JZGTE heads. How do I know....I personally tested!!
Rods are just as strong as 2JZ rods, how do I know.... I personally tested
1UZ pistons are manufactured in the same fashion as 2J pistons, so you assume that they are close to the same strength.(I should go measure the ring lands)
This being said, then in theory as long as the block holds together, a stock form 1UZ can do 1200rwhp out of the box, although I have yet to see any hard evidence of someone attempting to push the max ouf the the 1UZ. Usually the internals get upgraded anything after 600rwhp. It used to be pretty well accepted that a 2J could only handle 600rwhp, we all know that just is not true. I would truly love to see someone see how far they can take a stock 1UZ.
That being said, how much HP can a stock LSx motor take without upgrades? Might be similar I guess, but the motor alone is going to cost you 5K, where as a good condition used 1UZ.....$350. Now you can spend the other $4650 on the turbo conversion and electronics.
I have a local friend with a turbo LS400, only 9psi, but at 9, that things moves.
I have had two supercharged 1UZ's, one with a M90 and the other with an M112. My recommendation.. DON'T DO IT!!!! Neither charger is big enough and the parasitic loss is awefull.
In my personal opinion, LSx swaps are way overdone. Easy, yes, very easy and in many cases even though the cost is more for the motor, the end result for the power output desired can be less than other swaps. But again.....OVERDONE!!!! So you open your hood, and guys are like oh, cool, a vette motor, then move on. I see so many LSx swaps, they bore crap out of me. Dealing with an LS6 FD swap right now.
SuperRunner;1888615 said:In my personal opinion, LSx swaps are way overdone. Easy, yes, very easy and in many cases even though the cost is more for the motor, the end result for the power output desired can be less than other swaps. But again.....OVERDONE!!!! So you open your hood, and guys are like oh, cool, a vette motor, then move on. I see so many LSx swaps, they bore crap out of me. Dealing with an LS6 FD swap right now.
IJ.;1888851 said:We have a TVS 2300 waiting to go on the Soarer, personally I think it's too much blower for the 4.0L But Al wants to go ahead with it..
Kyle Hartman;1889080 said:I may buy a 92 ls400 and use it. Would the trans in it work for the swap as well? The dude lost the title and is selling it 1000obo. Which in my eyes isn't bad for the car. It looks taken care of and has no mechanical issues. Miles aren't high either
