Sside;2039709 said:
If you don't go up to 2.5 you will increase slowness.... Bigger pipes means more speed duh... Just do it....
Just to comment on this comment. The thinking here is slightly flawed. You have to match the pipe to the application. Too big means loss of pressure which means you cant get enough air into the intake in the short time it has. Too little means restrictive so not enough air will be waiting to get into the intake.
Its a common misconception. People think big turbo = big power. That's also flawed. Your engine can only take so much air at its given stroke timing. An overly big turbo wont do anything other than increase spool time. You need a turbo that is matched to the volume necessary throughout the powerband. Same with piping on intake and exhaust. You can go too big. Now... to figure it out using physics and all the math calculations isn't straight forward and easy, but I believe its there.
My SP6262 is actually a bit too big for my 7M's needs so I have a later spool. However, it does hold power throughout the power range so I don't get a dropped boost curve at my top RPM so I am happy with it. Once I put on a Quick Spool Valve (QSV), the spool time should be closer to what I actually expected so I don't have that big hammer hit the car late in the game. It's really my only complaint. My ignition cut is set for 6200 rpm so I get 2000 rpm of full turbo before shifting. That's not a lot of time.. lol.
And finally, for the DM intercooler, expect to have problems with the crossover pipe because they used some blind person to measure it and do the bends. It wants to NOT be bolted where its supposed to (by about 1.5") and the angle wants to put it through where the stock airbox is rather than the fender hole. I just tossed mine.
