Devin LeBlanc;1791791 said:Yes stock intake manifold and throttle body. Shawn had no problem going 9.44 on his 7m with stock manifold![]()
That's so awesome your motor is looking great i love the dark color look
Quin;1792153 said:I'd just go to a tubular man, they're really not expensive. I found mine on Louisville CL for $100 with a waste gate. lol
This made more sense imo for Devin because he had already gone external gate with his CT.
Devin LeBlanc;1791979 said:Did some more measuring for the design on the cop setup. It will still work with the stock ecu, It will be plug and play direct bolt on setup, It will include a 6 channel igniter, and can still use it with the stock manifold and throttle cable bracket retaining cruise control.
NashMan;1792158 said:there is big reason why he is still running stock rooting and intake ect, his car is an auto same as yours, in 5 spd cars this extra piping really up set's on/off boost because of shifting and pretty much gives you limp dick throttle response
Turbo Habanero;1792194 said:that kinda sucks to here i really want to go FFIM but there so pricey but i don't think ill ever break into the 9's let alone 10's
Devin LeBlanc;1779322 said:So here is the current list of specs
7MGE Block .20 over and Surface decked
7MGE Head, stock valves, surface decked, all valves lapped and checked for leakage. DDS Performance valve springs, seats and retainers. DDS Performance mild bowl job. Stock GE cams's, Adjustable cam gears
JE's 9.0:1 FSR Forged pistons 83.5mm .20 over, Slip fit wrist pins
Eagle H Beam Rods (ARP bolts) (Slip fit wrist pins)
Cometic 1.3mm Head gasket
Stock 6M crank (STD size Main and Rod)
Clevite 77 (NDC) STD Main, rod and thrust bearings
OEM Toyota Oil pump (shimmed 5mm)
OEM Toyota timing belt and pulley
RC Engineering 1200CC Injectors
GT35R .82 T3 Exhaust housing
Stock ECU W Greddy Emanage Blue and Lexus AFM
Stock Exhaust manifold with 38mm External wastegate, Open Dump
CNC CT26-T3 Adaptor
Stock Intake manifold
DDS Performance Custom Mandrel bent turbo back exhaust
DDS Performance Custom Mandrel bent and tig welded aluminum intercooler piping
Tial Q 50mm BOV
Stock A340E Auto trans (Custom shift kitted Valve body)
3000rpm re worked stall
Engine will be blueprinted internally with a micrometer and bore gauge. (I was taught to never use plastigauge unless I really have to) Cams will be degree'd with a degree wheel and dial indicator.
Will update as I go! List is looking nice![]()
