The MkIII Photo Dictionary! Lets do it
nsngarage
210
Pittsburgh, PA
So I just came across this project today.. Apparently it's dead? Because I'd be willing to tear my car apart (more so than it already is) just to get this going, Im a mechanic, So I could offer some write-ups as well.. And I haven't read the tasks yet, just wanted to drop my .02 in here first.. I'll head over to the task lists now.. Hopefully we can actually get this going.. Like I Said I'll offer any help I can.. My car is pretty much tore down now, and is going back together shortly, very clean, so my pics wouldn't be too bad..
Please let me know
Joshua
Supracentral
10
I think the original poster sold his Supra. I know he hasn't been on here for a couple of months.
Project needs a new owner.
nsngarage
210
Pittsburgh, PA
son of a.... so that kinda kills it.. unless someone else around can provide what dugums was gonna do.. the skeleton and such for the site.. was he planning on hosting it as well? I have done a lot of websites and such in my day, but I don't have the time nor the expertise it seemed he had.. :(
anyone? :p
Supracentral
10
I can provide all the hosting and templates, SM's server has plenty or room. That isn't the issue. I simply don't have the time to manage a project of this scope. This is going to be lot of work.
7M-KDL
Seeking high numbers
OneJArpus;1334349 said:
i'd be willing to do this but i'd need a picture of an engine bay the same way and as close to stock as possible. I'll search around and see what i can dig up.
my motor is still stock minus a strut tower bar and lex afm. other than that it defiantely looks stock(and dusty/dirty) for now. i can get a pic of it this weekend if you want.
kotu100
1,899
Easton, Ma
i'll be having machine work done on my crank soon, i could get pics of the removal, during, and reinstallation process.
nsngarage
210
Pittsburgh, PA
yeah that sounds good, let's get this going again.. Once I drop my engine back into my car it'll be really clean, we have anyone around that's decent with photoshop or whatnot?
nsngarage
210
Pittsburgh, PA
OneJArpus, are you able to build the actual site? I'll help with what I can, when I can, but if you can get a skeleton started, we can get this rolling.. let me know.. Im gonna recopy the list dugums had once I find it.. then we can see who would be willing to do which part :)
nsngarage
210
Pittsburgh, PA
ok, here's the content list brought back to a fresh page, if you see that something is missing, fill it in, or if you have a picture of one of these items (if it's possible, and clean :) ) you can send it to me and i'll try to start organizing some of this crap (hopefully a TON of it :) ) joshuakcallahan@verizon.net, i dont care about the file sizes, just get em to me, i'll try to throw a couple write-ups together soon also
nsngarage
210
Pittsburgh, PA
Head
Valve Covers
Valve Cover Bolts
Cams
Cam Gears
Valves
Valve Springs
Porting and Polishing
Head Gasket
Head Bolts
Studs
Block
Cylinders
Cross Hatch
Pistons
Piston Rings
Rods
Crankshaft
Oil Pump
Oil Squirters
Lower Timing Belt Cover
Front
Rear
Upper Timing Belt Cover
Front
Rear
Timing Belt
Timing Belt Tensioner
Drive Belts
Water Outlet Housing
Thermostat
Power Steering Pulley
Power Steering Belt
Power Steering Reservoir
Power Steering Pump
Power Steering Lines
Power Steering Rack
PPS
Non - PPS
Power Steering Fluid (ATF)
Power Steering Maintenance
Air Conditioning Condenser
Air Conditioning Compressor
Air Conditioning Lines
Air Conditioning Refridgerant
Air Conditioning Maintenance
Electrical System
Alternator
Battery
Starter
Body Wiring Harness
Engine Wiring Harness
ECU
Oil Pan
Exhaust Manifold
Intake Tract
Upper Intake Manifold
Manifold Gasket
Lower Intake Manifold
Manifold Gasket
Throttle Body
Air Filter
AFM
Accordion Pipe
Intercooler Piping
Intercooler
Bypass Valve
Blow-off Valves
ISC
Dashpot
PCV System
Coil Pack
CPS(7mgte)
Distributor(7mge)
Spark Plugs
Spark Plug Wires
Fuel Rail
Fuel Dampener
Fuel Pressure Regulator
Fuel Injectors
Cold Start Injector
J-tube
Fuel Pump
Ignition Timing
Radiator
Radiator Hoses
Overflow Bottle
Vacuum System
EGR System
Exhaust Manifold
Turbocharger
Exhaust
Turbocharger Elbow(7mgte)
Downpipe
Catalytic Converter
Test Pipe
Resonator
Muffler
Suspension
Front
Shocks
Tems
Non-Tems
Springs
Ball Joints
Control Arms
Swaybars
Wheels
Tires
Wheel Bearings
Rear
Shocks
Tems
Non-Tems
Springs
Swaybars
Tires
Wheels
Wheel Bearings
Differential
Open
Limited Slip
Torsen
Drive Shaft
Transmission
r154
a430
w58
Subframes
Front
Rear
Gas Tank
Gas Lines
Body
Front Bumper
Front Header Panel
Front Grille(s)
Front Signals
Front Emblems
Headlights
Motors
Housings
Top Panel
Fog Lights
Front Lip
Brackets
Front Fenders
Hood
Windshield Nozzles
Windshield
Doors
Trim
Targa Top
Mudflaps
Side Skirt
Rear Body
Rear Bumper
Taillights
Spoiler
Hatch
Rear Quarter Windows
Hatch Glass
Side Windows
Side-view mirrors
Glass
Motor
Heater
Interior
Dash
Glove Box
Gauge Bezel
Gauges
Climate Control
Ashtray
Center Bezel
Audio System
Shifter
Center Console
Steering Wheel
Gauge Switches
Climate Vents
Seats
Carpet
Door Panels
Speakers
Cargo Cover
Interior Plastics
Seat belts
Illumination
Rear Defroster
Weatherstripping
Antenna
8,898
Supracentral;628900 said:
I can set you up with an SSH account on this server so you can build it live here.
Maybe http://dictionary.supramania.com ? :icon_bigg
Nice site. That isn't what the Bible actually says. Turds like Benny Hinn, Jack Van Pimpe only say that so you send them your 10% that you don't actually owe them.
Why can't the pictures be uploaded to Supramania Wiki? Since it recieves at least some financial backing.
At some point, that .com era surplus of bandwidth is going to run out. And at that point today's internet providers will be faced with the harsh reality that the public seems to think that the value proposition of the Internet only works when you provide service to the public at 1/10th of what it really costs to provide it.
I have to pay for upload and download speed, in addition to usage. And people complain about the airlines...they haven't seen anything yet. Nice write up.
The pictures should be labeld as Toyota calls them. It will help when you order parts.
Supracentral
10
I had no idea what you were talking about for a minute... When SM doesn't resolve domain, (like http://dictionary.supramania.com, or http://nick_m.supramania.com) it sends you to the "default" site on the server, which happens to be my personal domain/page - that's the page you saw - let's not drag this conversation off topic with that.
Why can't the pictures be uploaded to Supramania Wiki? Since it receives at least some financial backing.
Where do you get the idea that it receives any financial backing? The only backing it gets is my wallet...
Also, the wiki is getting shut down and I'm slowly moving the content into the articles section of SM.
Not enough people use the wiki to make it worth the overhead of maintaining it.
Back on topic:
Agreed.
OneJArpus
2,798
Someone please take pics of their STOCK engine bay. Take close ups of everything and an overview of the whole engine bay. I have some free time so i can start something
I'm using these two pics for reference so far. Heres my list of parts that can be seen from the pics. Let me know if i've missed anything.
ENGINE BAY PICS
ABS UNIT
WIPER MOTOR
HEATER VALVE
WIRING HARNESS
BRAKE BOOSTER
BRAKE MASTER CYLINDER
CLUTCH MASTER CYLINDER
CRUISE CONTROL ACTUATOR
INJECTOR RESISTOR
IGNITOR
FUSE BOX
BATTERY
RADIATOR
RADIATOR HOLD DOWN CLAMPS
AIR BOX/FILTER
AFM
ACCORDIAN HOSE
CT26 TURBO
POWER STEERING RES.
TIMING BELT COVER
FAN SHROUD
ALTERNATOR
INTAKE MANIFOLD
3000 PIPE
INTERCOOLER PIPING
FUEL PUMP RESISTOR
TEMS COVER/SUSPENSION COVER
AUX FAN
COOLAN OVERFLOW BOTTLE
HOOD LATCH
HEADLIGHT MOTOR
COIL PACK COVER
COIL PACK
VALVE COVER
PCV SYSTEM
WATER NECK
BSVS SENSOR
COLD START INJECTOR SENSOR
COLD START INJECTOR
BYPASS VALVE
CHORCOLE CANISTER
WIPER ARMS
HOOD
WASHER FLUID LINES
HORN
ALARM HORN
RADIATOR CAP
FAN CLUTCH
FAN
TURBO HEAT SHIELD
O2 SENSOR
TURBO ELBOW
THROTTLE CABLE
THROTTLE LINKAGE
EGR VALVE
DIAGNOSTIC PORT
OIL FILLER CAP
VACUUM LINES
OVERFLOW LINE
UNDER CARRIGE
GAS TANK
MUFFLER/RESONATOR/CAT/DOWNPIPE
DIFFERNTIAL
HALF SHAFTS
TRACTION ARMS
LATERAL ARM
REAR SUB FRAME
DRIVESHAFT
DRIVESHAFT CENTER SUPPORT BEARING
TRANSMISSION
TRANSMISSION MOUNT
TRANSMISSION PAN (AT)
BELLHOUSING
OIL PAN
ENGINE BRACKET
FRONT SUBFRAME
FRONT LOWER CONTROL ARMS
TIE ROD ENDS IN/OUT
LOWER IC PIPE
CRANK
AC COMPRESSOR
RACK AND PINION
INTERCOOLER
POWER STEERING LINES
LOWER RAD HOSE
RAD
RAD BUSHINGS
CALIPERS FRONT/REAR
OIL COOLER
OIL COOLER LINES
AC LINES
TRANS COOLER LINES
SWAY BARS F/R
ENGINE MOUNT/BRACKET
DRIVESHAFT LOOP
BRAKE LINE
suprarx7nut
YotaMD.com author
Nov 10, 2006
3,811
Arizona
www.supramania.com
I'm about to start reassembling a stock 7MGTE, so I can take some pics as needed. I'll be trying to document it well anyways, but if there are specific pics needed for this, I'm happy to take some. :)
OneJArpus
2,798
take close up pics of just about everything in your engine bay. You do NOT have to do individual but group pictures by sections. top left bottom left etc etc. But let it be clear and visible if possible.
My boy just picked up a MKIII thats stock so i may take pics of his.
Clip
The Magnificent Seven
Oct 16, 2005
2,738
9
Virginia
whats the status on this? is anyone getting the pictures, or does anyone have a list of pictures obtained already?
