bigaaron said:My bad, the 1N4001 diodes will work fine. I got mixed up, it's 1N4001-1N4007 you want. The 1N4xxx are all 1amp, and the last digit is the voltage rating.
I'm getting rusty on the semiconductor part numbers, I used to know most of them by heart.
bigaaron said:All in a days work... :icon_bigg
JK, thanks for the good feedback, I'm happy my ramblings helped at least one person. :biglaugh:
5uprahboy said:No-one?![]()
bigaaron said:I saw your post, and it does look completey wacked out. I just haven't had time to look into it. The piston GB is killing most of my free time.
This is a good question for Jetjock, I know he could explain it in 10 seconds flat.
jetjock said:Well, I'm gonna need more than 10 seconds
Yeah, it's screwed up as far as labeling but the pin numbers and colors are correct. The photo is also correct. The four pin goes to the TCCS, the six (5 wires) to the coil packs and tach. What makes you think the six pin runs to the ecu? Keep in mind the colors in the book don't refer to the device side of a connector because they can vary.
jetjock said:Huh? Iirc the coils should have two pin connectors. Edit: Ok, I see what you mean. You're talking about the sub harness connector that's in between the ignitor and coil pack harness. It has 4 pins but further divides down to two pin connectors for each coil.
One of the wires from the igniter doesn't go to the coil pack area. It branches off to feed the the tach and diag block. The coils only require 4 wires, a common +12 and 3 ground triggers. Hence you have 5 wires total with one blank in the 6 pin connector.
Bottom line is there are 4 signals from the ecu to the igniter using a 4 pin connector and 5 signals leaving the igniter to the coil packs and tach using a 6 pin connector. The labeling on the online schematic is wrong on the igniter side but the pins numbers are correct. Make sense?
jetjock said:Both of your drawings seem to be the same and both are wrong. I can only tell you how the stock 7MGTE setup works. ECU to igniter is 4 pins and igniter to coil packs is 6 pins with one missing and one going to the tach. Except for the mislabeled igniter signals it's wired just as the book shows it. I dunno how much clearer I can make it.
Edit: Just so you know the ground wire on the coil pack mounting plate is a drain and has no bearing on the ignition system working but it should be connected for other reasons.
