25 RA is for a MHG (probably an HKS unit). It means Roughness Average, or how smoothe the surface of the head and block are. A MHG has to be pretty smooth to ensure a proper seal
jdub said:And it could be a combination of things too...air in the system from a leak, fan clutch, radiator cap. They can all add up to cause weirdness in the cooling system.
Oh course, Andy could be right as well...a BHG. It's worth it to make sure the cooling system is up to speed 1st.
Chris - You want to run a clutch if you stck with the stock fan.
johnathan1 said:The engine would take longer to warm up, and it would get really annoying to hear the fan roaring away constantly, especially on the freeway, big HP loss...
starscream5000 said:What would be the downsides of running an aftermarket fan that was bolted directly to the waterpump pulley John? This is also assuming the fan is the same size diameter as the stocker and is positioned in the fan shroud at the right depth....
JSHeinrich said:Ok I just did an oil change and the oil was like a milkshake big time. I would take pictures but my camera is broken. My fill tank for the radiator has not lost anything but when i pulled the cap off the radiator it was very low, so for some reason it's not pulling anythign from the fill tank.
With a stock head gasket, I still have to get the head machined to make sure it is not warped, correct? I can't see it being anything else other than a BHG but my dad is trying to think of 1000 different things because its a lot of work and he is tyring to make sure its nothing else.
Any tips on the bhg repair would be greatly appreciated. As well as anybody else's opinion on what I should do..
JSHeinrich said:When I put the hg on, should I use any kind of gasket sealer like permatex copper spray? Or should I just not put anyhting on it at all?
buckshotglass said:You better read this...
http://www.supramania.com/forums/showthread.php?t=29335
