TbcMorris' post fire CT build
tbcmorris
SM Expert Thread Derailer
Mar 14, 2007
1,820
PRUVEN PERFORMANCE MILFORD CT
couple updates.....im 95 percent sure i locked down an engine.
sold old supension gotta ship it out when i get a chance probably monday
here some pics of what ive been up too
engine block out 1500 miles after it went in :(
header panel scrtched up from then engine
after DAing
started block sanding it to cut it down
ready for primer
intercooler installed
little bumper modification to help get some more air across the intercooler(im going to buy an 89 and up front bumper and get a replica turbo a duct for it eventually)
new suspensions ride height
reppin the shop
soooooo that's about it. ill know for sure about the engine probably monday. then i onlty have to piece together a few more things and get this pig back on the road.
Depends on the product you use Josh but they should have tech sheets to cover it, I painted a friends bike some years back and found the additive changed the final colour on the plastics (was a pearl white job) so I ended up blowing a full final coat with additive over everything (wheels/frame/plastics)
tbcmorris
Mar 14, 2007
1,820
ok i have a paint guy in the next town over...i make sure i know exacty how the product works before i spray anything.....this is kind of why i didnt primer yet. i wanted to tak to him first so he coud recomned a product and technique
Yep 500cc less flow at the same rpm :)
I look at the QS valve as a way to have great top end potential while maintaining reasonable spool times (keep in mind a big modern turbo at 1psi will feel like a ct26 at 5psi)
The other approach is to use a normal size housing and have it hit very hard at low RPM, I have enough traction issues as it is so wouldn't go this way.
(Brad has and easily lights off his big rubber on the widebody car)
