IJ.;1621365 said:Can't believe B ever "whines" having met her, she's a honey![]()
hahaha, i can't really fault her on that actually
anyway ill reply to your pm sean, good to see you fixed some issues!
paradox616;1621378 said:hahaha, i can't really fault her on that actually
IJ.;1621302 said:Excessive whine is a bad sign G![]()
Especially when it comes from the missus!
honeydew;1621479 said:Are you saying that because the whine gets funny or higher pitched when the compressor blades get chewed?
Bud-dum pow!
IJ.;1621498 said:Usually indicates an out of balance CHRA, failure isn't far behind Sarah.
(Gordon's GF is a babe I'd happily deal with any minor "whine" she may have and do my best to solve it)
IJ.;1621828 said:Cool you and B will have to come up for a visit and take me for a ride![]()
IJ.;1621909 said:My "guess" is the Flapper is being blown off it's seat at higher flows.
LOL there's bits of Fat car everywhereparadox616;1621947 said:In the video that's your old dash IJFatty lives on!
Preload will only get you so far as then you risk top end spikes when the WG can't open far enough to control it, I went through all this with my 3540r and it's small internal gate,gets worse with tighter AR's.SupraSean;1621962 said:so it needs MoRe...Preload? lol gawd do these gates suck
IJ.;1622099 said:LOL there's bits of Fat car everywhere
paradox616;1622322 said:I didnt tell you guys this but i had the turbo on the bench not long ago, using a pressure valve I watched how far the gate opened, I've worked out you can preload it till about 18psi before the gate can't open far enough to work properly as preload reduces the travel the actuator linkage has, mines set to 12psi currently, i might try preloading it to 18psi IJ and see if how well boost is controlled.
