The F-body guys are running engines that are inherently imbalanced. I6 engines are a very different system. The vibration with solids isn't bad at all - it's a lot better than a FWD DSM with one solid one stock setup.
GrimJack;953947 said:The F-body guys are running engines that are inherently imbalanced. I6 engines are a very different system. The vibration with solids isn't bad at all - it's a lot better than a FWD DSM with one solid one stock setup.
GrimJack;953981 said:I dunno about subjective, it's rather easy to measure.
For instance, my buddy with the DSM - at idle, his keys bounce around and cause a nasty racket, his rear view mirror shakes badly enough that you can't see through it, and anything loose in the car will shake. When he had TWO solid mounts, it was nuts.
My car with solids, at idle makes no additional noise - no key rattle, my spare change in the coin tray doesn't move, I can see out the mirrors perfectly.
The Supra with solid mounts is absolutely more vibration that stock, however, it's not even close to the nuisance it would be in most other vehicles.
6M here. The motor has been rebuilt, but not balanced. I've also had the mounts for longer than the motor, and it felt the same on the old setup as well, which was a 'from the factory' untouched bottom end.Poodles;954993 said:What cranks are you guys running and has the motor been rebuilt and balanced?
Mine's not nearly that smooth...
Sawbladz;953955 said:This is seriously subjective. I put poly bushings in my car (front only so far) and I don't know if I can handle the added vibrations. I'm afraid when I get the rears in I will hate the car.
The idea of solid motor mounts, to me, is not a pleasant one. I guess I will buy some poly mounts and hope I don't end up hating the car.I guess these are the sacrifices on the way to intermediate power.
