dugums said:Gotcha :icon_bigg .... I was just making sure, because when I go to a motorcycle shop and see all the new shiny bikes, I usually end up buying something right away, lol :3d_frown:
lol
tlo86 said:you could always get a scooter to start off with![]()
clueless said:here's my finding from the Yamaha store should I buy a Yamaha for a first bike...
AF1JZ said:My suggestion is to stay with something no bigger than a 600cc to start out with. I would also suggest getting a used bike as well. Then when you feel comfortable with riding, get a new one.
I have an 06 CBR600RR and it's a great bike even if you aren't a beginner. Fast as hell and is perfectly balanced.
Joel W. said:For an extra $700 in mods you can get a slip on pipe and power commander and this bitch will scream...
http://www.clarity.net/~adam/buying-bike.htmlClueless said:One thing about buying used bikes would be you'd never know if their hot or been maltreated, not that you couldn't find out. Also I really like the 07 body style better then the older ones.
Clueless said:link/pics/sounds clips?
Joel W. said:Scorpion exhaust vid. (before and after)
http://video.google.com/videoplay?d...11&start=0&num=100&so=0&type=search&plindex=0
Scorpion slip on pipes for $391
http://www.motorcycleproshop.com/detail.asp?product_id=520-1363
Power commander for $259 on ebay
http://cgi.ebay.com/ebaymotors/Powe...AZR-04-05_W0QQitemZ130124160083QQcmdZViewItem
How much additional power will it give my motorcycle?
There are many variables to each application. The Power Commander allows for tuning to the perfect air/fuel ratio will ensure that the engine can produce the maximum possible horsepower for that given combination.
Consider that a typical street rider spends a great deal of time riding in part throttle conditions. Shown below are two graphs of a motorcycle before and after installation of the Power Commander. The top graph line shows the horsepower curve accelerating and the lower graph shows the corresponding air/fuel ratio. You can see a large horsepower increase between the two. The red curve shows a typical stock motorcycle with minor performance modifications (slip-on exhaust).
The blue curve shows that same combination with the Power Commander installed and you can see that the line is nearly straight. Consequently, the rider will feel a large improvement while riding the motorcycle. It is very possible that the peak wide open throttle horsepower is unchanged. The correct air/fuel ratio number (say 12.9:1 or 13.2:1) depends upon many factors like combustion chamber design, but what we want is that figure at every point in the curve (straight line).
Tuning with Power Commander
Base Map - The Power Commander is supplied with a given (base) map stored in the microprocessor. This (base map) is typically a map that has been developed to provide an improvement for most combinations matching the map description (i.e. stock bike or performance exhaust and air filter).
In general we have found that a typical stock bike has areas in the fuel curve that are far from optimal for drive-ability and performance. We could say that they are typically 70% optimized in stock condition and 60% - 65% with minor performance modifications. After installation of the Power Commander with the base map, we would expect to see 85% - 95% optimization. Power Commander Alternate Maps - Each Power Commander is supplied with a number of alternate maps on a CD-ROM and all the maps are available for download on our web site.
You may notice that we have a map specifically for "Brand A" slip-on exhaust and another for "Brand B" slip-on exhaust. Although the difference between the two maps is likely to be very small, these difference will increase the optimization for that given combination. If you have a "Brand C" exhaust and we do not have a specific map, you should find that "Brand A" or Brand B" maps will provide a good improvement on your bike.
Nomad707 said:dont buy a buell.. they are all bad news.
poor quality.
i had a blast and a lightning, both were shit.
crappy chinese parts, poorly manufactured parts, cheap alloys, crappy mirrors, 5,000 pound mufflers (the only reason they put it under the bike is because its so damn heavy)
ALL bad news.
and dont buy a 250...
after one week you will feel retarted. (no power)
buy a 500cc one lunger.. alot of torque for fun, and last a while.
ive owned 6 bikes in 3 years.. so i know what im talking about.
i stick around yamaha and kawi, kawisaki has always been my brand of choice. (last bike was a 1993 kawasaki ninja ZX-7RR)
poor quality.
ALL bad news
OneJoeZee said:Call some insurance companies and ask.
Prices vary. A lot.
