Some R154 Transmission Rebuild In Progress Pictures
PIONEER
Wallet Wide Open
Raleigh, Nc
Started a rebuild on my R154 transmission. Have some of it apart but still have a long way to go. Need some special Tools to take some of the bearings out. Harbor Freight is dry on Shop presses right now so the project is on hold :biglaugh:
supra90turbo
shaeff is FTMFW!
32
MA, 01440
Nice! Good to see you guys are still around, pioneer.
I can't wait to rebuild mine. The gearset just hanging in mid air held by the vice is so cool looking.
tsuper92
supra addict
Apr 7, 2005
1,376
mass
i did mine about a month ago.the shifter fork's coming out with the alignment pin's was a little tricky for me.hope you don't mind me putting up a couple of pic's in your thread.pm me if you want me to take them down:icon_bigg
this is a break down of the main shaft and counter shaft
you can see the mdc bearing has more roller's then the stock one
the input shaft
a few pic's of the main shaft
Reign_Maker
Has cheezberger
Aug 31, 2005
5,767
Florida
That intimidates the hell out of me... Gimme a motor, I can tear it apart all day... Gimme a tranny like that, and Im like wtf?
So has anyone come up with a solution to the thrust washer weakness?
tsuper92
supra addict
Apr 7, 2005
1,376
mass
a couple of guy's where having new thrust washer's made,but didn't want to sell any till they where tested.one thing i noticed taking mine apart,was alot of sludge in the slot's of the thrust washer.i'm sure that would help it starve for oil,but i'm sure people have probably broke them in new rebuilt tranny's too
PIONEER
Wallet Wide Open
Raleigh, Nc
TSupra92, Did you buy a Press or have a machine shop press the gears off for you? I'm on hold right now til HarborFreight gets a new shipment of Presses. the 6Ton press they have in stock is not tall enough. Those Locking pins/balls did give me some trouble.
S383:- My 2nd Gear Syncro was acting up so I figure why not rebuild it since I'm building the engine.
Reign Maker:- not having the right tools is the holdup right now. Once I got the casing off and struggled with the Locking pins on the shifter, I did question for a minute what I got myself into now :)
tsuper92
supra addict
Apr 7, 2005
1,376
mass
i have access to a 30 ton press.
did you pull the bearing off the output shaft yet?i used a puller for that.
to bad your so far away,i'd let you use the press.
Justin
Speakers?
Spokane, Wa
x2
I hate transmissions ;\
Mr.PFloyd
I am the Super Devil
Jun 22, 2005
3,964
Mississauga, Ontario
Jake, IIRC it is just the amount of heat being transferred around that area gets too hot for what ANY metal could handle. We would need some kind of better ventilation IMO.
Also, does anyone know of any company making straight cut gears? That would be a super easy way to strengthen it and make more power to the wheels.
PIONEER
Wallet Wide Open
Raleigh, Nc
Yeah I pulled the Output shaft bearing off last night with a Pully puller and some long bolts bolted to the HarborFreight bearing puller :icon_razz
tsuper92
supra addict
Apr 7, 2005
1,376
mass
cool.you must have the main shaft ready to press the bearing's and gear's off.the counter shaft only has one bearing to press off.the input shaft only has one.it's just the main shaft thats all the work.
