getting bumped once again lol,
I'm about to purchase the r154 rebuild kit from MDC as one of the bearings in my gearbox is shot, in regaurds to the thrust washer, I was under the impression it was only likely to shatter in large HP applications or if the operator adopts a "Vin Dieselesque" shifting technique from first to second? Is either of those statements true? If so, at what power level will there start to be a risk?
I'll replace the washer when the gearbox is apart, but getting a new one machined up, then treated sounds expensive and could cause more headaches than its worth.
Is it worth just getting some strengthening treatments done to a stock washer? Or due to it being sintered is it always going to be inherently brittle?
One final thing, and not really related to rebuilding the gearbox, but what oil do you guys run? I've been using redline light weight shockproof (Yes i know it's not for syncro engagement boxes) and god damn it is good. Will using alternative gear oil/lubricants help prevent washer failure?
