***SM Member Horsepower List***
Harnasiu
11
POLAND
mk3_7m;1876789 said:
nice.. grats
What size A/r on turbine? on the gt4088. also what engine management?
cheers
Turbo it's GT 4088 A/R 0.81 .
Mods:
port/ polished head,three angle valve job,2mm HG,Ron R. FFIM,clevite 77 bearings,Probe pistons,ARP studs, eagle rods,clutch rps3200,Walbro 255, RC 750cc,Custom full 4inch exhaust,Innovate LC-1 , all controlled by AEM
First dyno 380rwhp/11psi on pump gas. Im waiting for Bc 272 and spring than we can push it to 30psi.
Albert
May 13, 2009
1,710
Tempe, AZ
507rwhp 408rwtrq- E85
1jzgte. proefi 128. BC 272 cams. MP-70mm turbo. 4" cat-back. 24x12x3 FMIC. 3" IC piping
15psi creeps to 18psi.
te72
Classifieds Moderator
6,610
7
WHYoming
Seems like it comes on pretty hard right after 4000, you breaking tires free around then, or is it pretty well sorted?
Also curious why you're only revving to 7k with your setup, and not really pushing the turbo much. I take it this was a baseline dyno just to see a low boost level? Not to rag on you or anything (you're further along than I am for sure), but I would have figured your peak hp would come right at the end, but it seems to have peaked around 6600 rpm... is something choking it?
...there aren't any fingers in your intercooler are there? :p
Harnasiu
11
POLAND
7m-gte
Gt4088,BC 272, BC springs ,port/polished head,three angle valve job,2mm HG,Ron R. FFIM,clevite 77 bearings,Probe pistons,ARP studs, eagle rods,clutch rps3200,Walbro 255, RC 750cc,Custom full 4inch exhaust,Innovate LC-1 , all controlled by AEM
Enraged
A HG job took HOW long??
24
Victoria, BC, Canada
GrimJack;1815917 said:
Getting there! A bit more and I'll have to add you to the list!
I know this is an old response, but we'll have to see what Bill can do with my car. Pretty much the same setup as before, just adding a water/meth injection kit, new turbo actuator, and fixing some issues.
Albert
May 13, 2009
1,710
Tempe, AZ
Just made 722rwho 618rwtrq at 30psi on my stock block 1jz. 1200cc, e85, dual 044, T70 turbo. .84ar, 3"dp, 4" exhaust, 272 cams. 20° timing. Tuned by tony at UMS on Proefi 128.
Really like to be on top of the 1jz hp list
MarkIII4Me
Project OVERKILL!!!
Apr 10, 2005
1,249
Charleston, SC
7mgte: 467whp and 426 ft/lbs of torque @ 18psi on 93 octane
Chart:
Vid:
http://www.youtube.com/watch?v=VGeuF48W_CI
Mod list:
*JE Pistons * Crower Rods * Crazy Head Porting * Custom Raised 7M turbo Cams * ARP Head Studs * HKS Stopper HG * AEM Cam Gears * Turbonetics Hi-Fi 62-1 Bolt-on Turbo * 5" Blitz SUS Filter * 1JZ FFIM w/ all provisions * Delta Fin Intercooler * Greddy 720cc low impedence Injectors * Aeromotive AFPR * Tial Q Bov * Trust Power Extreme II Exhaust * BIC Ceramic DDP * Fluidyne Radiator * Flex-a Lite Fans * Spec Stage3 Clutch * AEM v1 Rev.B Mod.C EMS *
CajunKenny
PULL MY FINGER. PLEASE!
Nov 15, 2007
3,255
Washington
Your turbo spools similar to my JT62. Coming on good at ~3500 rpm and peaking around 4500.
I love seeing the results of head work. Nice job!
