***SM Member Horsepower List***
MarkIII4Me
Project OVERKILL!!!
Apr 10, 2005
1,249
Charleston, SC
The torque starts peaking at 4500rpm, but the horsepower doesn't peak until 6000rpm. So the turbo is pulling all the way to redline.
Here are some pics of said head work.
CajunKenny
PULL MY FINGER. PLEASE!
Nov 15, 2007
3,255
Washington
Peak tq occurs around peak boost. It's making power to redline; but, that's mainly your head work and cams. Boost isn't increasing to redline though. Not unless you've got an 84mm under the hood that you didn't mention. ;)
mytmk3
643
christchurch
my latest tune
7mgte - Mp t70, tial v44, Toda cams Titan cam gears, comp cams valve springs, Je's and eagles, 1200cc injectors + dual walbro's, 3.5" catback 3"downpipe 2.5"&3" ic pipes large fmic, Ffim q45 tb, Link g4 ecu, Os triple plate clutch
422rwkw/566.58rwhp torque pretty sure needs to be corrected 1260nm
toyotanos
What will we break today?
2,841
Coon Rapids, MN
Tuned yesterday. Did well. Compressor was surging early on so we had to cut it off :(
Unofficial top power was 806 @ 33psi, but to make it safer we cut it off at 31psi, making 788.
Wastegate power is 573 @ 20-23 (boost creep'd)
I will post pictures when I get internet back at home.
GrimJack
Administrator
Dec 31, 1969
12,377
Richmond, BC, Canada
idriders.com
sunnysupra;1830609 said:
413hp 475 trq 7M stock head, crank, rods. JE 20 over. hks HG. stock upgraded ct26. walbro, vpc/afc, spearco intercooler and everything else STOCK! lol
Just squeaked in under the limit.
cricketjoe;1834283 said:
Can I be on a list? :)
Not yet. As of right now, you're #35 or thereabouts, you need to make it into the top 30 with a 7M to qualify.
toyotanos
2,841
Coon Rapids, MN
1Z Coils worked like a boss. No breakup at any boost level, timing was consistent and it ran very well at idle. More happy nothing broke, to be honest.
GrimJack
Administrator
Dec 31, 1969
12,377
idriders.com
Added.
mrsuprafreak;1843775 said:
Please add Mrsuprafreak
1989 MKIII 2jz Borg Warner 80mm Stock block and stock head 272 HKS, 850cc injectors, 4inch Custom exhaust
716.94 rwhp TQ XXX.XX @ 26psi
Added
NewGen;1846626 said:
MK III supra 2jzgte Stock Engine, Chinese gt45, AEM V2, 91 octane @18 psi
Added.
Torque;1857319 said:
My newest dyno sheet. Not as powerful as my 1JZGTE, but this is my current all stock JDM 2JZGTE. Mods are: Borg warner 83-75 turbo, Cast manifold, 3" down pipe to a 3" Greddy SP cat-back exhaust, Sard 800cc injectors, Walbro 400lph fuel pump, 12x24x3 intercooler and a AEM V1 EMS. Tuned on a mustang dyno at 17PSI. 420whp and 404wtq.
[/IMG]
Elli;1874830 said:
7M-GTE, BC272° Cams, BC Springs, JE-Pistons, Eagle Rods, S475SX, EMS8860
885HP 891Nm
Added.
Harnasiu;1897236 said:
497rwhp/15psi Pump gas. Please put me on the list.
Dude. That dyno sheet doesn't say 497rwhp, it says 408rwhp. That's not enough to get on the list.
Albert;1908219 said:
Just made 722rwho 618rwtrq at 30psi on my stock block 1jz. 1200cc, e85, dual 044, T70 turbo. .84ar, 3"dp, 4" exhaust, 272 cams. 20° timing. Tuned by tony at UMS on Proefi 128.
Really like to be on top of the 1jz hp list
Updated! Congrats, and welcome to the top of the 1J list.
Torque;1908384 said:
updated dyno with the addition of 264 cams and 18.8 psi.
Errr... for which car again? Not a lot of people are on the list multiple times.
mytmk3;1915843 said:
my latest tune
Added. That torque number sounds off, though.
Pics or it didn't happen. ;)
Albert
May 13, 2009
1,710
Tempe, AZ
Hey you updated mine wrong.
Should have said:
722rwhp 618rwtrq at 30psi on stock block 1jz. 1200cc, e85, dual 044, T70 turbo. .84ar, 3"dp, 4" exhaust, 272 cams. 20° timing. Tuned by tony at UMS on Proefi 128.
GrimJack
Administrator
Dec 31, 1969
12,377
idriders.com
Ya, I just changed the numbers... fixed now!
toyotanos
2,841
Coon Rapids, MN
toyotanos - 788whp/674 rwtq - 7M Eagles/83.5mm JE's, AEM, 1350's, E-85, Billet 6765 @ 31psi, +1mm valves, dual springs, P&P, BC 272 cams.
there, it's copy/paste ready!
lazer1100
24
AZ
Here is my Dyno sheet. Current mods: Stock 1jzgte , rebuilt twins at 18psi, mines ecu, SAFC 2, full three inch fencepole and turbosmart manual boost controller. Black is first run blue is second got very heat soaked was over 100 degrees that day.
Tgood
All throttle no bottle
Dec 16, 2005
206
ennis/dfw
What fuel pump are you using?
Plau000
135
Tucson
I'm wondering why you Moderators haven't added LAZER1100 to the Dyno list? He did everything you asked, except mention he has a 255 walbro fuel pump, and yet he has not been added to the list. There seems to be some treachery afoot.
