kwnate;1127901 said:Clock starts when you move, not on green. But keep at itnevermind, going with the pinks start??? :runaway:
xarewhyayen;1137916 said:UPDATE!!!
Ran again tonight.. got a much better launch, car felt great. It was nice and cool for the turbo :icon_bigg
http://i110.photobucket.com/albums/n119/xarewhyayen/DSCF1014.jpg
I am much happier with this, but i only could get 1 run in :nono: Launch rpm was much better but i could have gone higher with it.. 2.459 is a better 60' but i'm shooting for 2.0 which will probably land me in the 13's. Oh and it was on the tree this time, so my first tree experience thus the r/t.
Mods: 3" elbow, 3" hks replica dp, 3" test pipe, Tanabe hyper medallion cat back. K&N cone filter, Greddy profec e01@12psi with stock CT26. BFG g force sport tires (225/50r16 front 245/50r16 rear) on sawblades. Spec stage 3 clutch.
Kyle Hunter;1138832 said:Oh, and for some reason I was underthe impression that a .400 is a perfect light, but maybe that is only on a pro-tree?
arizzle;1138315 said:damn i should really find my old slip, i know i did a 14.2 on my old flat blk supra, mods were a custom full 3" exhaust incl DP, fipk, 60trim @ 9psi, 24x12x3in 2.5in piping and the rest stock =D
Nomad707;1138938 said:damn man.. supras are heavy..
i saw a guy run a 13.9 on a N/A del sol with a gsr :3d_frown:
i think im falling out of love with supra, and in love with mr2 =/
no im not bashing you or anything.. im just sayin i wish they made supras like.. a ricer. a tiny car with the same engines they originally came with.. i just looked out side after i posted this.. and looked at how long my door was on my supra... holy shit man..
Kyle Hunter;1138832 said:A 2.0 60ft will land you mid-low 13s. Are you bogging the launch or spinning? If spinning are you get wheel hop? Oh, and for some reason I was under the impression that a .400 is a perfect light, but maybe that is only on a pro-tree?
xarewhyayen;1141048 said:Bogging, The first run i ever did, i launched at 4000rpm and it hopped really bad.. I'm under the impression that i need the traction bars that a1 racing offers.. i just need to get a paycheck that doesn't go down the drain for bills so i can get my hands on them.
by the time i get to the track ( i head up after work ) i only have time for 1-2 runs, so tuning my launch hasn't been easy. I'm working on it, and Ive made 3 runs so far. a 16.xxx (wheel hop launch, popped outta 1st gear) 2nd run was a 14.9 (2.9 60'.. major bog launch) and the most recent 14.3 with 2.4 60" with a 3000rpm launch with a tiny chirp and medium bog. I keep improving, just gotta keep up the trend. My tires are also at 90% tread depth, if i keep toasting them up ill get better traction as i go.
jz*supra;1158340 said:[URL=http://imageshack.us][IMG]http://img376.imageshack.us/img376/6231/picsb5.jpg[IMG][/URL][IMG]
JDM 1jz powered mk3
MP T-61, crower 272's, 680CC injectors, Lightweight flywheel and driveshaft,
Nitto street slicks, HKS v-pro base map only, 18 PSI on pump gas
60' foot times are low because this was my first day at the track with the setup. I recently swapped a t-78 for a t-61 and 3.73 LSD to 4.3!
I also did not have a launch control so that was launching under vacuum from 6500 RPM! The nitto's hooked, [B][U]however my driveshaft's Ujoint exploded on the 4th pass. I also believe i shredded the diff and then snapped the shaft[/U][/B].
My plans over the winter are for a meth kit, proper tune, and a bit more boost.[/QUOTE]
Well done! You know you are fast when you start breaking parts. Old rule of thumb.
silver88;1159670 said:http://i421.photobucket.com/albums/pp295/turbogt40supra/10-21-08012.jpg[IMG]
Hey guys, I finally made it to the track before the season ended and was pretty happy with the results. Im on the left lane.
My mods are: Stock ct@14 psi, Lex/440s, an ebay dp with no cat and a blitz nur spec exhaust, and on 245/50/16 street tires. I still need to work on getting the 60' times down but I think a set of drag radials or slicks may be needed. The 111.98 trap speed also put me 9th on the 100 mph club for the import class at the track.[/QUOTE]
In what, a Miata? Got a build thread?
Nick M;1159680 said:In what, a Miata? Got a build thread?
