***SM member 1/4 mi. times list***
8,898
silver88;1159682 said:
Haha no not a miata... I believe the car wieghs 3600 with me in the car iirc . You can also check the 100 mph club at beaversprings.com. I believe it says the make of the car along with the mph. Also no build thread.. I really dont post alot just read and learn what I can.
You dumped a good amout of weight. Stock 5 speed hard top turbo is about 3550, without a driver.
That is about 403 flywheel horsepower at 3600 lbs.
silver88
12
State College, PA
Like I said its been awhile since I wieghed it... It may be 3600 without me in the car plus its a targa. I plan on going again next weekend so I can get a video.
8,898
:biglaugh:
You have a time slip. I believe your time. I just wondered how you got a stock CT to run so fast.
Boost Lee
Bee Doo Bee Doo Bee Doo
2,750
Indianapolis, IN
Nick M;1159741 said:
:biglaugh:
And there goes Mr. Nick giving the youngn's a hard time......:biglaugh:
To be completely honest here...I think that a BPU MA70 (Still with stock turbo),
Should ideally be in the 13's as they are.
I think we're all so used to seeing 14 and in some cases, 15 second time slips from cars that SHOULD ideally be running in the 12's and 13's.
And on Nick's note.......I'd like to see a picture of your compressor wheel!
(.....Waits for uploaded picture of a 57 trim CT). :icon_bigg
Jeff
supranasty
Yo Daddy
Apr 12, 2005
374
jamaica ny
Slow66;577469 said:
Here it is folks, a list of 1/4 mile times that will actually be updated.
There will be 4 sections. MKIII bodied (7m powered), MKIII bodied (1j powered), MKIII bodied (2j powered), and Other (ie. 7m dragster, 1uz mkiii, 7m/1j/2j mkii, etc)
Its kinda hard to make a list for every combo, so i think this will do for now.
All submissions must be accompanied by a timeslip or video. I will work on the honor system that the timeslip is actually yours. I will do top 30 for 7m powered mkiii's (since that is the majority), and top 15 for everything else.
Please include and a *basic* mod list with your submission!
Let the games begin.....
7m MKIII
1. besttrans - 9.951 @ 140.04 - T66, Accel DFI, gm auto
2. lvfinalstage - 9.97 @ 134.11 - gt4788@18psi, aem, gm auto
3. Slow66 - 10.55 @ 126.77 - T61, FFIM, vpc/afc, gm auto
4. Upgradedsupra - 11.00 @ 130.29 - RHC7 Turbo, 720's, TEC2, stock head/cams, FFIM
5. csabika - 11.45 @ 131.2 - pt76@36psi, JE's/Eagle's, Cometic hg, 2 walbro's, 1000's, VEMS ECU, ET Streets, custom int. mani w/Q45 tb, air/water
6. VanSupra -11.64 @ 120.33 - TRD Cams, forged pistons, Turbo A TB, fmic, T70 T'netics @17psi.
7. s turbo 87 - 11.725 @ 120.61 - 60-1 CT26 @ 20psi, vpc/afc, 580s, 75 shot, BFG dr's
8. suprakid24 - 11.77 @121.5 - GT4088R, FMIC, tial wg, AEM EMS, M/T street slicks
9. toyman1987 - 11.81 @ 117.49 - sp63, aem, 750's, a340 w/ 3200 stall
10. Buddafucco - 11.90 @ 123.7 - T61, HK$ WG, 22psi, 3"pipes, Walbro, AEM FPR, Greddy EMU, 4.30LSD
11. gixxer750 - 11.90 @ 123.5 - 2.0 60', 7m, t66
12. Suprarich - 11.95 @ 114 -1.73 60', Stock CT/IC, a340, vpc/afc, 70 shot N2O.
13. MRSUPRA - 12.0 @ 120 - SP61GT Lex/550's/supporting mods, stock 7M w/ cometic hg, Nitto DR's
14. drjonez - 12.111 @ 117.4 - sp57, emanage
15. lintlars - 12.12 @ 124 - gt 35r, rebic lc, lex AFM, 680s, r154
16. supranasty - 12.384 @ 113 - 60 Trim CT, Lex AFM, Walbro/550,stock intercoolers/afr, 5spd, 4.30's, DR's
17. BTZ - 12.704 @ 112.58 - 57trim ct, lex/550, safcII, 5spd, stock 7m
18. silver88 - 13.20 @ 111.98 - Stock ct@14 psi, Lex/440s, ebay dp, no cat, blitz nur spec, street tires.
19. 89turbotoy - 13.21 @ 106.6 - intake, 3" turbo back, 50 trim ct @ 14psi, 2.5" hard pipes, spearco style i/c, street tires
20. suprra_girl - 13.37 @ 106 - 46trim ct, 3" exh, 9psi,big IC, 2.5" IC pipes
21. The Reaper - 13.4 @ 104 - 5 spd, Intake/exhaust, Lex/550's, SAFC untuned
22. RTA Supra - 13.5 @ 104 - SC61, hardpipes, 3" turboback, street tires
23. Boost Lee - 13.76 @ 105 - Stock 7M-GTE, ct26 @ 10psi, 3" Exh, int. w/K&N, auto, Street tires.
24. WeDgE - 13.82 @ 106 - Blown T78@13psi, Lex/550s, 3" exh,FMIC, 4.30s, DRs, E-manage
25. OfnaRcR4 -14.05 @ 101 - 57 trim, shimmed gate, spearco , 2.5 harpipes, 3" exh w/ stock elbow.
26. staticpat - 14.1 @ 107 - Upgraded CT-26, stock 440s
27. RedEj8 - 14.209 @ 99.71mph - Stock ct @10psi, street tires, ARP's, OEM HG, MBC, LIPP elbow, 3" exh., K&N
28. xarewhyayen - 14.30 @ 102 - 3" turbo back, Tanabe hyper medallion cat back. K&N cone filter, stock CT26@12psi, BFG g force sport tires, Spec stage 3 clutch.
29. tissimo - 14.33 @ 95 - 2.0 60', Stock intake/exhuast, 10 psi
30. sterlingae - 14.69@ 95.8 - 5spd, 3'' exhaust elow back, air filter, bosch bov
1j MKIII
1. Twin 1jz - 9.48 @ 146 - twin k26's, slicks, and open exhaust
2. MattOneDizzle -11.67 @ 127 - 5 Sp, 61mm
3. jz*supra - 12.37 @ 116.05 - MP T-61, crower 272's, 680CC injectors, Lightweight flywheel & ds, Nitto 555Rs, HKS v-pro base map only, 18 PSI on pump
4. SupraRacer - 12.6 @ 112.8 - stock twins
5. claytonio disastro - 12.90 @ 108 - 1.8 60ft, stock twins, full exhaust, stock boost/ecu, bfg dr's
6. ForcedInduction - 12.96 @ 113.30 - 61mm w/ supp. mods, street tires, pump gas.
7. Mofo - 13.05 @ 110.02 - stock twins, custom int and exh, powerfc, ARC IC.
8. 921JZ-GTE - 13.08 @ 105.88 - stock twins @ 14 psi, ceramic clutch, 1 pc. DS, street tires
9. suprahero - 13.24 @ 112 - 5sp, GT35r, 540's, Walbro, Ported head, Crower 272's, FMIC
10. tissimo - 13.42 @ 112 - 2.2 60', t67, 17 psi, crower 264, aem
11. BlackMKIII - 13.46 @ 109.7 - stock twins @ 1.3 bar, 3" exhaust, RFL BOV, 2.5" piping w/ fmic, custom CAI, Walbro,AFPR,AFC, 4:30 LSD
12. DLM - 13.46 @ 101.45 - stock 1jz auto, stock i/c & pipes, 3" dp & exh, K&N
13. annoyingrob - 13.606 @ 103.21 - Stock twins, 15psi,Divorced y-pipe, intake, exhaust, Crower 272s, V-Pro
14. The Reaper - 13.72 @ 102.82 - 5 sp, intake, exhaust, stock twins, 11psi
15. onejz - 13.74 @ 99 - stock twins, DP, exhaust, K&N filter
16. Turbo 7M - 13.9 @ 102 - 5sp, stock twins@15psi, exh, dp/y-pipe, afc
2j MKIII
1. SD2JZA70 - 11.6 @ 122 - stock jdm 2j, GT76, Haltech e11, 1000cc, custom int. mani, 4" exh, twin disc, BFG dr's
2. Kyle Hunter - 12.37 @ 113.93 - SPSS700GTBB Turbo, AEM EMS, V160, Lipp traction arms, Eibach/Tokico HPs, 275/40-17 Nitto 555r, race weight 3840 lbs.
3. Dew511 -12.4x @ 125.xx - 1j head, T61, 550s, Crower 272/272, Wolf ECU, R-154, Street tires
4. tissimo - 12.647 @ 113.56 - 2.09 60', 2jz, stock twins, 16 psi , aem, street tires
5.
OTHER
1. mibrum - 7.44 @ 179 - 1.05 60' - 7m powered rail dragster
2. darkspeed - 11.26 @ 125.92 - Mkii, 6MGET, Megasquirt ,SPEC stg3+ (W58), LSD, ET drags, t61
3. Clifton - 11.67 @ 135.38 - '73 240Z, 7M, MHG, K&N, 4 puck, big turbo, injectors, exhaust, FMIC, standalone.
4.. ARZ - 11.75 @ 124.8 - '71 240Z, 7M, 5 sp, stock clutch, h20/meth, t4/60-1, 22~23 psi,
5.
supranasty
Yo Daddy
Apr 12, 2005
374
jamaica ny
supranasty -7mgte,lex/550,safr,60trim,stock block+intercooler,5spd,430s,DR,16lbs
12.384,113mph,1.760ft ETOWN 10-26-08.jpgCH]
click on slip to enlarge.
silver88
12
State College, PA
I made it to the track sunday for the last test and tune day and still could not break into the 12's although I did improve from last time ... Oh well maybe next year and sorry for the poor video quality as they were taken with my crappy digital camera.
TKMK3
29
Chandler Az
Ran the car on sat and ran 11.16 @ 118 on a 1.66 60 foot! I completely missed fifth gear and spun a little . . . . So a good track and practice my driving skills and im sure i can get a ten out of her ! Heres a crappy in car vid it was at night and the sound is a lil quiet so turn the volume up and fast forward about half way through.
http://www.youtube.com/watch?v=ew1chSIRQQk
Slow66
I think with my dipstick
Apr 3, 2005
1,457
Newington, CT
Tyler, just need a small "mods" list and I'll put you up there. I know a few of them, but I want to get them all on there correctly....
TKMK3
29
Chandler Az
Cool thanks! 66mm turbo completely stock head n/a cams, stock plenum and tb, tubular manifold, pro efi, 26x11.5 15 et streets, 23 psi
I went to Steele International speedway saturday. 5sp, pt67, 540's, Walbro, Ported head, Crower 272's, FMIC
rt........560
60'......2.089
330'....5.544
1/8.....8.334
mph....90.16
100..........
1/4.....12.586
mph....112.420
