nick88;1389877 said:Did you check your pcv system, vacumm leaks?
Zumtizzle;1389885 said:^whats your power band and which NGK plug did you use?
BCPR6ES or BCPR7ES?
supra_guy;1389888 said:Your idle is fine I've heard it in person..the ticking I would be more concerned about.
Zumtizzle;1389889 said:Check Resistance of the Coils.
Check Resistance of the SPark Plug Wires.
A conventional plug wire has a resistance of 10,000 to 15,000 ohms per foot of length--if it's measurably higher, the wire probably is bad.
Alec;1389893 said:The plugs and wires and brand new.
Alec;1389899 said:valves
Zumtizzle;1389900 said:Means nothing. :nono:
And my motors are Quiet, and my cousins motor i assembled has a 3.5 Straight pipe.....![]()
Zumtizzle;1389897 said:Check Valve Clearance.
I check this too when i do my plugs.![]()
jdub;1389907 said:It sounded pretty good to me on the video and the RPM is good. Might need to be timed...and it sounds like valve lash needs to be set.
