CajunKenny;1390307 said:The TSRM makes no mention of this.
I guess it wouldn't hurt to try? Or would it?
jdub;1390315 said:Jumping T1 and TE1 puts the ECU into diagnostic mode...you do not want to run this as a normal configuration. Dude...just set the timing like suggested numerous times. Your idle sounds fine.
grimreaper;1390327 said:NO how can you read base timing with out a timing light? you cant... follow the tsrm. there is no other way to verify this. seriously takes less then five mintues!
supra_guy;1390329 said:This is what I am conserned about. http://www.youtube.com/watch?v=3PVyhBNmjLw&feature=channel_page
Thats how mine clicks. Obviously you can't hear it when the hood is closed, but its quite disturbing with the hood open, and if 7m's naturally do this then good lord Im going 2jz.
R1GG5;1390333 said:My god, mine sounds nothing like that, that is NOT normal. Sounds like you have valve lash to me. I have heard 7m motors that have a slight tick(like mine) but nothing like that.
Alec;1390341 said:It's not that loud in person. Pat, does the sound get faster with RPM? That sounds more like valves to me, might want to get them adjusted. No biggie, though. My ticking sounds more like injectors, it gets faster and slightly quieter with RPM.
R1GG5;1390344 said:How do injectors tick?
nick88;1390384 said:When the flux capaciter turns on:sarcasm:
R1GG5;1390390 said:OOh, I completely forgot about that! My Flux capacitor busted a few weeks ago....man it was a bitch to replace! :biglaugh:
Alec;1390328 said:By listening to the engine? If it sounds better in diagnostic mode, then I know it's the timing, right?
CajunKenny;1390493 said:Not dis-crediting Taco here all; but, I want to add to his statement regarding the torque wrench.
Remember that a big torque wrench (1/2" Drive) will NOT work on smaller nuts and bolts. Even though it may have a range of 5 lbs to 150 lbs if you try to torque a 6mm bolt to ~12 lbs with a big torque wrench, you will break the bolt.
They make 3/8" and 1/4" drive torque wrenches to accomodate smaller nuts and bolts.
Sorry for the side note, I just wanted to save some folks some heartache!
Alec;1390498 said:I just had a friend come over with a timing light and he said that it was fine. The only reason it idles like that is because of my exhaust system and I'm running stock cats. Also because I'm running rich.
