Skid Plate
closetnerd;1523949 said:
"Lastly, keep in mind that nobody is going to thank you if you build / sell something that is capable of killing the people in the car behind you or the pedestrians beside you if it flies off at speed."
Proper maintenance avoids this.
I generally don't build things that fall off so that's a non issue.
whitemike
1,164
Winter Park, Florida, United States
This thread made me laugh a couple times, It's funny how when you post intelligent things, only the intelligent will pick up on it. The rest will be doomed to "HELPP!!!!" threads and the like, and those who have a clue will be replying with links to threads like this..
-Mike
closetnerd
35% Biotic
Feb 15, 2009
173
Huntsville, Alabama, United States
-Mike
That's cute, and what did you provide?
GrimJack
Administrator
Dec 31, 1969
12,377
Richmond, BC, Canada
idriders.com
supradjza80;1524176 said:
I would definitely not call it useless, it just does not change over the LARGE range of temperatures that toyota deems acceptable. I see no issue with this. When the car is getting too hot the stock gauge starts moving where it should. Just because it is incapable of showing you the difference between 190F and 200F does not really matter.
Also, looking at the graph above what does FSD stand for? I assume this is the % of full temperature displayed on the gauge? I think it would have been better to graph actual temperature from a thermistor or actual very accurate gauge vs. gauge position on the stock unit. I would like to know the range of temperatures the stock gauge thinks sitting right in the middle is ok for.
The range is closer to 190-240F that it thinks is ok. I'm not fond of the idea that 240F is ok. If my temps are heading north of 210, I want to know about it now, because I'm going to stay out of boost at the least, and possibly pull over, shut off the car, and read a book while it cools down. FSD stands for Full Scale Deflection - and he did both charts, FSD vs current and FSD vs temp. Here's the temp graph:
attachment.php
Here's the original thread if you'd like to read up on it: http://www.supramania.com/forums/showthread.php?47479-Temp-Gauge-Calibration
ValgeKotkas
2,224
Over the pond
I asked this once in another thread and got no real answer IIRC... once more: Ideally, where should the undercover begin and where should it end? Is the size and all in pic in post nr 4 good or not? (from air flow in -> flow out point of view)
Is stock ideal? Anyone with a nice picture of a stock undercover attached to the car? :)
