should i buy 1983 toyota 4x4?
Clip
The Magnificent Seven
Oct 16, 2005
2,738
9
Virginia
called him a few days ago, the truck is his cousin's and he says he'll be able to get a title for it. im hoping :)
Clip
Oct 16, 2005
2,738
9
Virginia
shaeff, what do you think about marlin crawler's shackle lifts? i'd love the full kit but cant swing the $1700 price tag yet
shaeff
Kurt is FTMFW x2!!!!
11
Around
Eh, they're alright. You don't really gain anything by extending the shackles. (and keep in mind, 3" shackles will only lift your truck 1.5") Not really worth it, IMO.
Right now, I'm riding on BFG Mud Terrains, still open diffs front/rear, and have little trouble getting around whatever I have encountered. I've just never been a fan of shackle lifts.
The school on lifting that I preach, is to only go as high as you NEED to go, unless you need tons of suspension travel for something like rock crawling. Otherwise, stuff the biggest tires (and appropriate gearing to match) under the truck to gain ground clearance, but keep the roof as low as you can.
High center of gravity FTL.
shaeff
11
Around
No problem. :)
Those Firestones look decent. There was a reason I didn't go with them, but I can't remember what it is. LOL. They appear to have a thicker sidewall than the BFG's, which is good for preventing sticks and whatnot from puncturing them.
If you use stock rims, you could likely fit 33x10.5's (if you can find them) with a small amount of massaging here and there.
Clip
Oct 16, 2005
2,738
9
Virginia
:( boss bought the truck out from under me, so this means i get to fix it up and charge him an arm and a leg :)
Clip
Oct 16, 2005
2,738
9
Virginia
Scot;1199906 said:
I would buy this truck for $300.00 without tires....
when he bought it there was so much shit to wade through about "can't find the title" and "i'll get it to you eventually" made me want to stay as far away as possible.
JDM 1JZ
I hate Tires
Aug 31, 2005
301
Cherry Hill, New Jersey
better check that frame real well front and rear hangers, under the cab, look for cracks bad rust holes etc Hilux frames snap in half and rot out bad like theres no tomorrow, otherwise that trucks 700+ in a part out alone, 300 just for the solid front axle to someone doing an SAS to their rig
Clip
Oct 16, 2005
2,738
9
Virginia
only pickup rust issue i've seen is rear fender rot (terrible) and the occasional rusty frame (not extreme)
