I just did something a bit stupid and now my car is running like crap and making a weird noise. I use that additive called Mystery Oil from time to time to clean out and lubricate the fuel system. They recently changed they're bottle style and its now more concentrated than it was before. I accidentally put too much into the gas tank (enough for two 15 gallon fill ups) and the car started to run extremely rich after I used about a quarter tank. Once that happened checked the bottle and found out my mistake. I topped off the car with more gas to try to dilute it and adjusted the VPC and GCC to fix the AFR issue but then it started misfiring. I looked online to see if anyone had done this too and it turns out several people had made the same mistake. The only thing I saw that was happening to the car other than running rich was that a few people said it was fouling their plugs. I had been planning on changing out the plugs anyway so I figured I was gonna have to use more gas in the tank to dilute it further before anything would get better. It is my daily driver so I kept driving it. I used up 3 quarters of the tank and refilled it. The car started to run better and I had to adjust the VPC and GCC again, but the idle was still off. I checked the plugs and 3 of them were fried and the others looked like crap too; so I changed them out. The car felt better right off the bat but when its under load it makes this weird sound like if something is loose and vibrating. It only does it when its under load and sometimes on deceleration. If the car slowly accelerates it doesnt make the sound. Usually around 2500RPMs at higher RPM's it seems fine. I havent tried boosting on it yet and I'm not planning on it until I know what it is. The car feels better with the new gas and the idle has improved but every now and then it will stumble and the idle will be off again and will slowly pick itself up again. Im hoping that not all of the additive is out of the fuel system yet and thats why its doing that, as for the sound I'm thinking maybe something in the valvetrain has gone horribly wrong or maybe an injector but i guess time will tell. I guess the moral of the story is to check the back of the label before you pour anything in. Wish me luck
