San antonio
san supra
833
san antonio
help plz
http://www.supramania.com/forums/showthread.php?127449-hks-adjustable-bov-broken
and the final product for now
CT26smoker
223
Houston
Did you pull a vacuum on the HKS to see if the internal check valve on the diaphram is holding ?
This is a common problem with any used ssqv.
If they were ever run without the filter, fine road grime that makes it past the car's air filter will cause the check valve to not seat.
You need one of those hand pumps for pulling vacuum to check them.
Hook it up, pull a vacuum on it, and watch the vacuum gauge.
If it takes any less than a few seconds to leak down, the check valve has dirt in it.
If it won't hold any vacuum at all, there is a chance that the diaphram is shot.
Suprapowaz!(2)
2,870
San Antonio, Tx.
Special thanks goes out to David and his brother (sorry, forgot your name). I couldn't have drop this engine in by myself. I forgot something though.... forgot to hook up that coolant hose to the hard wrap around pipe. No biggie though. A friend of mine has a set of Snap On long reach hose removal/installer pliers that I can use to put the hose on. Now just have to connect my grounds, driveshaft, etc. I'll be busy for a while.
---------- Post added at 04:54 PM ---------- Previous post was at 04:47 PM ----------
BTW guys, this is where I got my start. When I was looking to upgrade my supra I was looking for a website that had info on MKIII's. This is what I found. At the time Supraforums.com or supramania.com didn't exist. This did. http://www.supras.com/06/main/index.php
If you do a member search and type my first name in "Rufus" you'll see I'm still in their database. Later I found supraforums.com.... then supramania.com.
---------- Post added at 05:01 PM ---------- Previous post was at 04:54 PM ----------
san supra
833
san antonio
miguel: did you get you car finished?
mike: do you have your turbo yet?
darrell: hows your build?
giovanni: dont you run a hks bov? maybe you would know whats up with mine. (sorry if i googled your name wrong)http://www.supramania.com/forums/sh...s-adjustable-bov-broken&p=1601801#post1601801
nicole: did you set your car on fire yet? i had to stop myself from doing that many times. lol
my car is up for any meets!...for now
S.A. supra
2,405
Buda, Texas
I got it last week but didn't have a chance to drop it in yet. I'm in Florida right now won't be back till Monday. I hope to drop it in next weekend. But I might need some adaptors or new oil lines. So I might need to order some stuff. It might take another week after that
1988ma70supra
553
San Antonio, Texas, United States
I think i have a set of adapters for the Garret turbo oil housing back in the garage. Ill look for them and you can have them but i wont be home till about a week and a half. Ill let you know
---------- Post added at 12:50 AM ---------- Previous post was at 12:47 AM ----------
My car needs to be broken in but its done. I had a minor fuel leak and that set me back a bit but i took care of it after lots of head scratching. I took a little time off for a vacation and wont be back till about 10 days but I'm down for a meet as well. We can at least go to that burger joint on topperwein on a friday.
san supra
833
san antonio
mike there isn't any heb's in florida! lol
miguel i did a hard break in and i think thats to way to go. my 2cents. (almost no boos but lots of high speed decel in gear to seat the rings bad ass)
CT26smoker
223
Houston
I did also, and that was with hard to seat Total Seal rings.
Worked out great.
1988ma70supra
553
I've heard of this method but i haven't understood it very well. Do you accelerate the car hard then just down shift keeping the RPM's high?
san supra
833
san antonio
you dont do much boosting, i maybe maxed at 4psi in my break in.
lets say your going 70mph, then i would down shift into 4th gear and let the compression of the motor slow me down to 55mph.
hell you could even put into 3rd gear at 70mph for a higher rpm.
when doing this your fighting the compression of the motor and forcing the seals to seat in a safe way. (as i understand high boost is not as safe)
i did this kind of driving all the way to austin for a meet.
tyler: your car is loud and i like it!
slopra
Formerly tsavenged
Jan 15, 2010
284
San Antonio, TX
Lmao Travis...its cool though everybody calls me that its my brothers name and thanks, you should be in the car and hear when I'm downshifting omg it sounds sexy lol oh and I found a package of zipties, lemme know if you need them...
san supra
833
san antonio
lol i have bags of zipties!
wtf? your name is not travis?
why would you be called your brothers name?
my parents called me daniel (my bro) sometimes but thats because they were pissed and not thinking.
well i guess will have to learn another name. lol
miguel did i clear anything up? make sense? ha
i will seriously come give you a ride in my car to show you if you want
slopra
Formerly tsavenged
Jan 15, 2010
284
San Antonio, TX
my name is travis lol you called me tyler, my brothers name, in your other post lol
do you rev match when you down shift when breaking in the motor? i try not to shock my driveline
supra.usa
7m.performance
Mar 22, 2009
60
lmao.. dave just give up with names!! yes i have the same old school HKS SSBV! never had any problem! plus i like how sounds, better than new ones. but thats just me, oh and i do have an strong vaccum line to it tho!! and Giovanni is good but mine is YOVANY. lol
