San antonio
1988ma70supra
553
San Antonio, Texas, United States
I still ended up going to SAR for import night, I was representing VW in my friends Jetta though. There was quite a few people there although I'm sure more people would have shown up if the weather had been better. Luckily it didn't rain and the track was dry. We took a few videos of the passes, ill try an upload them soon.
Suprapowaz!(2)
2,870
San Antonio, Tx.
I was going to go too, but came up with a problem. I tried to bleed my brakes and found out that my front brakes do not work. I bled my Master Cylinder (MC) twice again, and all four corners. Rears work fine, front still didn't work. I disassembled the MC, and all the seal inside looked fine. I'm thinking my proportioning valve (PV) shut off the front brakes. I stopped working on it last night cause I had to take the family out to eat. Today I'm going to disconnect the front brake line after the PV and pump the pedal to see if anything comes out. If it does then I'll do the same just after the ABS module and check there. I'll see what I come up with.
Suprapowaz!(2)
2,870
San Antonio, Tx.
Oh, I thought it was on your camera. Did you run your car that night. I just found out that San Antonio Imports Night was cancelled that night and moved to this Friday the 21st.
1988ma70supra
553
Suprapowaz!(2);1875067 said:
Oh, I thought it was on your camera. Did you run your car that night. I just found out that San Antonio Imports Night was cancelled thatnight and moved to this Friday the 21st.
No I just ran his car that night; I don't want to run untill I fix the exhaust leak that seems to be getting worse every start up. I have all the gaskets I'm just waiting on the studs to come in.
Are you gonna make it out on the 21st?
1988ma70supra
553
sterlingae;1876279 said:
Do you guys ever cruise by biffs or Lowes meet in san Antonio on Friday nights? If everyone is rolling out to sar I may go check it out.
I used to go to Biffs all the time but havent been in awhile. I've never been or heard of the Lowes meet. My exhaust stud kit just came in yesterday and I havent gotten a chance to change them so running the car down the track is out for now, but I think i might go anyway to spectate if its Import night. Did you ever gets your brakes fixed Rufus?
Suprapowaz!(2)
2,870
San Antonio, Tx.
Not yet. I just got in. I'm going to bleed them in about an hour with a vacuum pump and see if it's any better. I'm speculating that I have a bad master cylinder, and I just got this one as a warranty replacement for the last one. If I get the brakes working good in the next couple of hours then yeah, I'm going to SAR. If not I'll let you guys know by at least 3pm this afternoon.
