Ryan's 92 build thread aka NashMan
NashMan
WTF did he just wright ?
Aug 5, 2005
4,940
17
Victoria BC
Well I have order a bunch of junk and did some work oh the fun
aww looks it so cute
then I chopped it's bloody head off
2.5 inch pipe oveld then re rounded again
it's been a wail
and that's it for now
Rollus
593
Paris, France
Hey Ryan, good to see you coming back to your build.
Very nice work on the head!
Nice cam, but to much duration to my taste.. I prefer mine:
I see shimless buckets. Have you installed ARP inserts in the head bolt holes?
NashMan
Aug 5, 2005
4,940
17
Victoria BC
Yes but I have more lift
I posted the spec's see if can get them again
@50 we have a nice number of 236.7 dur and peek lift is 411 (10.4mm) (stock is 201 @50 and 7.54 of lift)
this is with cam gear what ever that means cause there are 2 spec's
so really these are really high rpm cam shaft and will be perfect for the 9000 rpm motor I am building
now there so much over lap that i wounder if i might need to use a vacume pump
for fun here is he biggest cam for the 7mgte by brain cower
http://www.briancrower.com/makes/toyota/cam_card/bc_0322.pdf
dur @ 50 is 226 and peak lift is 8.6
brain cowers full blow race cam for the 2jz
http://www.briancrower.com/makes/toyota/cam_card/bc_0303.pdf
@50 232 and a lift of 11.48
so ya these cams are pretty big
you will have to duble click to go to photo bucket then you can zoom in from ther
Rollus
593
Paris, France
Yep I remember your spec, we have discussed about it on FB, pics are also on your SF thread.
Here are my specs:
Close lift, shorter duration
NashMan
Aug 5, 2005
4,940
17
Victoria BC
My Ronni K yellow bushing are here for my sub frames
time to get rid of the temp solid spacers i have
NashMan
Aug 5, 2005
4,940
17
Victoria BC
No Ron made it then I bought it off a buddy. Sadly I have to chop it some more some times I wish I made my own but meh I got it for a good deal
NashMan
Aug 5, 2005
4,940
17
Victoria BC
Well parts keep coming in
I got to take my boat out the other day to bad it was shitty trip windy as hell and installed a hitch on my x runner
NashMan
Aug 5, 2005
4,940
17
Victoria BC
Well turns out I will be building 2 cars at the same time
doing a foreword facing intake manifold, inter cooler, piping install and map ecu
wail doing mine
but some shit came in and now i can start working on my car and this is what I have gotten done so far
took apart my oil oil system and have these gems to play with
Zazzn
l33t M0derat0r (On some other forum) n00blet here
Toronto/SF Bay area
Looking good! I should have let you know I was in Victoria a few weeks ago with my wife for a few days to enjoy the sights. We took the ferry from Seattle.
NashMan
Aug 5, 2005
4,940
17
Victoria BC
Well that last post didn't go as planned but I did pick up a haltec 2500 elite and screen and have gutted out most of all the after market wireing I added
oh ya I may have or possibly ordered a dog box gear set from PGS trans mixed with the stillway l400 shifter it should be a hole lot of fun
  • Like
Reactions: eraezer
NashMan
Aug 5, 2005
4,940
17
Victoria BC
Got a reply back from PGS so excited they test fit each gear set before shipping them out and I have custom gear set for my 3.91 rear end as well
1st is 2.60 2nd 1.84 3rd 1.26 4th 1.0 5th 0.78 stock is
  • First Gear: 3.251:1
  • Second Gear: 1.955:1
  • Third Gear: 1.310:1
  • Fourth Gear: 1.00:1
  • Fifth Gear: 0.753:1
so I loose a little bit of top speed but meh I revving to 8500 possibly 9000 but my pauter rods are kinda heavy so we will see
