Rolling paint job
phoenix6
Rockin' the blades
Aug 13, 2006
1,138
Serena's Place ;)
hottscennessey said:
ehh I'll do it for sure. I'm gonna go with white, for ease, and lack of hastle.
I'll definately test it out on a fender or something first tho.
I read most of the thread here, Im doing it sometime very SOON. after the carssmall hickups are fixed. Im doing black, straight up, and Im also painting my interior black and getting new carpet and seats, seats later along with carpet, but the paint job, Hell yes Im doign this, why not? Ill post pics
bryanintexas
aaarrrrrggghhhh!!!!!
Apr 4, 2005
605
spring, texas
LMK when you do it, I'd like to see the results in person.:biglaugh:
phoenix6
Rockin' the blades
Aug 13, 2006
1,138
Serena's Place ;)
Oh shit another person in town, yeah dude, youre welcome to come chill and watch it all unfold as we do it, if u wanna help I have no complaints :evil2:
PROJECT N00b
XBL: Mkiii DriFt3r
May 22, 2005
1,660
honolulu, california
keo said:
i want to try this, for $50 its worth shot. i was quoted 1500 just to paint the car(the same color)
what is a roll-on? is it the same roll that you use to paint your house with?
its called roll on because thats exactly what you do with the paint, you roll it on. and you use rustoleum or boat paint as someone mentioned.
phoenix6
Rockin' the blades
Aug 13, 2006
1,138
Serena's Place ;)
One thing I didnt see, do we have to clearcoat it? if so, can we get that rolled on too or do we take it somewhere?
PROJECT N00b
XBL: Mkiii DriFt3r
May 22, 2005
1,660
hmm, im assuming that its something that should be done...wait not assumed i think its best you do so. ive seen a spray can form of clear coat...but itd be a good idea to get that part done at a shop...because i dont know about rolling the clear coat. haha.
phoenix6
Rockin' the blades
Aug 13, 2006
1,138
Serena's Place ;)
well, how much u think they charge for that little bit? I just want like 2 or 3 coats, just enough to sheen.
Fuckin Maaco haha
Mr.PFloyd
I am the Super Devil
Jun 22, 2005
3,964
Mississauga, Ontario
no clearcoat required, although it wouldnt be a bad idea to get extra shine. the final coat and buffign gives it a good shine.
edit. stay away from maaco with any clearcoat. they use this cheap stuff that falls off in the car wash.
phoenix6
Rockin' the blades
Aug 13, 2006
1,138
Serena's Place ;)
Oh and so I dont have to look around, Im in Houston, where can I get the paint I need and what was the exact type again? I saw type somewhere in here, but WHERE the hll do I go?
trucker
88
i'm bad, i'm nationwide
shot a ghetto paint job like this once a few years ago, used sherwin-williams equipment enamel. worked ok, not bad for the 60 bucks or so i had in it
rough sanded it, shot 2 coats outside in the dark, never got around to wetsanding it,rolled the damn thing a week later...
guess osha saftey red wasn't a safe color after all...
cwapface
Supernerd
Eugene, OR
www.dylanwiggins.com
I used clearcoat in a can from the local auto paint store for my wheels and it turned out great, it has a button on the bottom that you push to mix the paint with the hardener inside. It is absolutely clear unlike stupid duplicolor or other regular spray clears, but it costs $20 a can so it might triple your budget
tubbie
Yes, powerful Jedi....
Apr 4, 2005
821
Hoschton, GA
Took this from the 4age forums...
Before you start, I would suggest learning some things first or even better, test it out on some spare part till you’re familiar with how to do it right before you hurt your car. And also, some of the stuff on this post isn’t directly from me but from the original guy who came up with the idea. You should read through http://board.moparts.org/ubbthreads/showflat.php?Cat=0&Number=2331682&page=0&fpart=1&vc=1 before you even start on this post as your question might have been answered already. But if you’re too lazy, I guess you can continue on. First off, I’ll start with the supplies you’ll need. (And by the way, all.. and I mean ALL.. the supplies can be purchased at your local HomeDepot warehouse)
The Supplies
A) Package of high density foam rollers (usually comes in packs of 4-6 about 4in. long). You’ll need this much because you don’t want to use the same roller with dried paint on it.
B) Paint roller stick (I shouldn’t need to say this, but yea.. some of you know why)
C) Mineral Spirits (1gal.)
D) Disposable paint trays (0.50 cents – CHEAP!)
E) 5-6 sheets of 400 grit wet sand paper / 5-6 sheets of 600 grit wet sand paper / 5-6 sheets of
800 grit wet sand paper / 5-6 sheets of 1000 grit wet sand paper.
F) Wooden paint mixer sticks (they are free @ HomeDepot! OMG!)
G) Plastic bucket or container. (be imaginative.. whoever asked “what do I use to mix the paint and thinner?”.. you need to wake up buddy. If you’ve ever eaten out and ordered Wonton Noodle Soup to go, they would give you a plastic container.. and that would solve your “end of the world” problem.)
H) Polishing compound. I use Turtle Wax since I’m a Turtle Wax guy.. but you can basically use any polishing compound. Just make sure it’s a paste compound and not the liquid form.
I) Foam brush (Used for hard to reach places that the rollers can’t paint)
J) Masking tape (to cover up any areas you don’t want to paint over)
K) And finally – the paint. (More explained on this one below incl. misc. information)
The below
First off.. to clear up the confusion everyone seems to be having. Tremclad is only available in Canada. The equivalent of Tremclad in the United States is called Rust-Oleum. You won’t be able to find “Tremclad” anywhere in the US (or maybe you can, I dunno’.) The type of Rust-Oleum paint you should use is Rust-Oleum oil-based enamel paint. (http://rustoleum.com/Product.asp?frm_product_id=18&SBL=1&dds=16) The HomeDepot in my area only stocks the quart size cans. I would say you’ll need about 2 quarts to cover the entire car, underside of the hood and trunk, door jabs, etc.
As for the amount of thinner you should mix in with the paint, I really can’t figure a way to explain that. Generally speaking, depending on the amount of paint you’re mixing… you’re suppose to mix it together until the viscosity of the paint is like that of water but just a tad bit thicker. What I strongly suggest people who aren’t sure how to do this is to test it out on something else first until you get the right setting. I would rather waste money on the paint and thinner than to mess it up on my car.
The most important thing for this project is prep work. I cannot stress this enough. Please please please, clean your car first before you do anything. Then wet sand the paint that’s already on your car with 400 grit sand paper. You can use a more coarse paper if you have no patience but I prefer 400 grit because theres less of a chance for mistakes. When you’re done sanding with 400grit, clean up your car again to get rid off all that paint dust and whatnot with a wet rag. Once it’s clean, apply 2 layers of paint with a roller.. do not apply massive pressure on it, just enough so that the roller is rolling and the paint is going on smooth and evenly. Once the paint dries (about 6hrs later.. but can take longer or shorter depending on the temperature) wet sand it with 600 grit sand paper then clean your car again.. you don’t need to flood it with a hose or anything. Just get a damp cloth and wipe your car off. Repeat this process again and again until you have 6 layers while using finer and finer grit between coats for wet sanding. As for me, when I have time, I’m going to do 8-10 layers because im retarded like that.
Disced
Pie + NYQuil = FTW
Edmonds, Wa
rakkasan said:
ghetto, nothing less. Does anyone wonder why MKIII's are considered cheap toys for kids? The rationalization in this thread, to honda owners no less, should clear up any remaining doubt as to why the stereotype exists.
If you want a cheap shit job, roll away baby! If you want a quality, professional job, spend the required money
Dude... Who considers MKIII's cheap toys for kids? :3d_frown: You? Jean Claude Van Damme? Ask me if I give a shit who considers what car what? Stereotype just a little more my friend.
Some things in life are a big scam. Paint and body is ONE of them. If you do your own prep work and your own wet sanding, a 200 $ paint job can look AWESOme. The next time I go get a paint job; I'll make sure to ask every single person 'how much you think this paint job cost?' And when they reply with a couple G's, I'll just nod my head. :biglaugh:
It doesn't take 50,000 to have a sick car... It just takes DEDICATION and GOAL setting.
That is all.
