Rod knock?
wiseco7mgt
dirty mechanic
Aug 12, 2007
811
queensland
The pistons all depend on where the crank is sitting at the time..doesn't' mean anything. Good to see you got the bolt out without using any extreme measures.
Supracentral
10
Dude that's 100 percent normal... If you are this unfamiliar with motors, tread very lightly.
dumbo
1,911
Albera, Too Far North
old man to the rescue hehe
are you sure he didn't hammer in a Torx bit??? trust me they work good.
are you following the TSRM?? It'll help.
Epy
74
Florida
No I'm just unfamiliar with an inline 6.
I've only owned a buick and two hondas. On one of my hondas when I opened up the engine, 4 and 2 were in the same spot, and 3 and 1 were almost at tdc. I would've figured with a 6 ... it would've followed the same pattern and there would be 3 pairs of pistons at the same position insted of 4 and then 2... just using my common sense ...
but I guess not.
jdub
Feb 10, 2006
10,730
Valley of the Sun
If the crank was turned to TDC, #1 and #6 would be at TDC and the remaining pistons would follow the same type pattern you described. In this case, the crank was not set at TDC.
black89t
boost'en down 101
Oct 27, 2007
951
humboldt, ca
grimreaper;1235357 said:
holy shit! cover the oil passages and lifter bores (terminology?) if your gona drill it!
where's the inblock cam on the 7m?
just giving you some shit. :rofl:
and btw you have to start somewhere. so feeling like you don't know shit is normal. i remember rebuilding my old 2000 yamaha blaster back in the day. i was so scared i was going to fuck it up. i had it bored over .40 then slapped it together and it ended up running really strong. i sold it and it runs fine to this day.
Epy
74
Florida
I got the lifters out and everything off the head(alternator bracket, housing etc.)
Is there way to take the valves and everything out without a valve spring compressor?
(following the tsrm)
jdub
Feb 10, 2006
10,730
Valley of the Sun
A deep socket (the right diameter), a rag and a rubber mallet ;)
I hope you kept the lifters in the correct order so you can put them back in the same location.
Don't lay the head combustion chamber down on a hard surface, you risk bending the valves. Actually, a valve job is something I leave up to a competent machinist.
Epy
74
Florida
so you think I should just leave the valves in there for the machine shop?
I'm planning on getting new valves though anyways, and upgrade everything for the head. idk yet
should i do the whole .1mm oversize or what?
Supracentral
10
If you are going to have a shop build the head, just give it to them assembled.
Just remove the cams - this puts all the valved in a "closed" position and helps prevent damaging them.
jdub
Feb 10, 2006
10,730
Valley of the Sun
Going with oversize valves will only be useful if you plan on a high HP build (big turbo) and need the flow through the head...there's a lot more to it than just the valves. If you are staying with a NA motor, oversize valves on this motor will not do anything for you.
Epy
74
Florida
I have everything removed,
There was something odd I found, on the number 6 cylinder, there was NO carbon?
(#5 was cleaned by me) you see, besides directly on the valves, there isn't any.
The water jackets and the crankshaft and EVERYTHING on the inside are very rusty? Could that just mean they used water instead of actual coolant. (My grandpa said he's never seen that much before and he's opened and done a few engines)
*EDIT*
OK SO, if you've read any, I do want a HP build, I AM Getting turbo, SO NOW
SHOULD I DO OVERSIZED VALVES?
wiseco7mgt
dirty mechanic
Aug 12, 2007
811
queensland
Sometimes you can have a coolant leak from the h/gasket into the cylinder and it does a great job of cleaning the head and the piston.
wiseco7mgt
dirty mechanic
Aug 12, 2007
811
queensland
No you don't need bigger valves, the stocko ones have been pushed well over 600hp before and the fact you have a tight budget it wouldn't make sense.
Before making any rash judgments on the head get it checked out by a machinist who will test it and can weld up any corrosion that may have gone to far.If it makes you feel any better i've seen worse heads that were repairable but they were all pretty straight which just a photo doesn't tell.
Supracentral
10
#6 tends to run hot, it's not unusual.
When coolant is exposed to exhaust gas it becomes acidic and creates lots of rust. If the motor was run with a BHG between compression and the water jacket (most common 7M failure mode), it may have been that.
Did the motor sit for a long time?
If you're planning on over 650 rwhp, go ahead, otherwise the head will flow good enough in stock form.
AJ'S 88NA
2,419
Florida
Is the #6 were the HG went? Probably got steamed cleaned. The cam in the pic looks to be in pretty good shape, can you get some better pics of the peices and parts?
And yes it looks that they used water instead of coolant.
Epy
74
Florida
Yes crank is rusty.
I don't know if the motor sat for awhile or ever had a BHG, don't have history.
(didn't even have manual, I jsut ordered one off of factoryautomanuals.com(GREAT SITE BY THE WAY!!)
OK SO NO i wont be doing oversized valves, im only going for 400 or a lil more(I want ot be able to stay with the w58 for now because I don't know if ill have enough money for an r154)
I'm getting a 272 regrind anyways
Alright well now it's just up to me choosing a machine shop. it's ready to go...
one last question, IS arp like the only trusted brand for bolts and studs because everyone and their mother seems to use them.
I'm going to get them, but it was just a curiosity question because i acutally don't think I've seen any other brand being used.
I can't remember if I actually showed you guys the video of that actual 2 spun rod bearings I found...
but heres a pic...
jdub
Feb 10, 2006
10,730
Valley of the Sun
Epy;1236738 said:
*EDIT*
What I've been reading is you changing your mind more often than a guy changes his underwear. That (and a few other nuggets) suggests you need to read more and do less at this point in time.
Good luck...I think you're going to need it.
Epy
74
Florida
I have always said since I received this car the first day was that I am going to turbo out... point out anywhere in this thread once that I said I wasn't going turbo...
but thanks anyways for the luck..
