IJ.;1979215 said:How flat are the covers after that?
LOL nice save!NegativeGeForce;1979753 said:IJ, you were right. After the covers cooled they bowed like 5mm.
I stuck a shim in the middle between the head and covers and bolted down both ends to bend them back then stuck the entire head (junk head) in a gas BBQ at 500 degrees for an hr. The valve covers are flat now
I know this post is a year old, but did you ever try a heat relief with an oxy torch after welding, just to heat the aluminum all up to relieve the stress from welding?IJ.;1979223 said:LOL I never had any luck welding on the stock covers no matter what I tried.....
Always warped even when bolted down..
Yeah I did Sean, they had a memory and pulled back again after cooling...funky_monkey58;1983965 said:I know this post is a year old, but did you ever try a heat relief with an oxy torch after welding, just to heat the aluminum all up to relieve the stress from welding?
hvyman;1984077 said:So how is your tig holding up so far?
SupraOfDoom;1984075 said:I remember when we used to chat every day! It's been a long time nice to see you doing what appears to be very well!
NegativeGeForce;1984092 said:Hey thanks, yeah I've been talking a long time about building something sick, time to do it finally, lol!
Found out it gets expensive pretty quick. I spent as much on tools as parts so far.
I need to dump like 12 grand more into it for the car to be where I want it.
When are you gonna finish your car?
DeMoN2318;1984413 said:Is that really blood all over the mill?
