Hold on...... just stepping backward for a moment on the brake line leak issue: Do the Evo calipers have a tapered seat at the bottom of the brake line boss? Mine haven't turned up yet so I can't check.
If the MK3 OEM lines are made for a tapered seat in the factory caliper - but the Evo uses a banjo bolt & washers, then you'd be lucky to get a good seal using the OEM Supra brake lines, since they aren't designed to seat on a perpendicular surface.
Out of interest, if anyone needs the info to match something up, the 7MGTE head-bolt washers are 3.0mm thickness, I grabbed a set off a mate today, and will dummy-fit the lot to check alignment once the calipers arrive.
Interesting about the dust shield acting as a heat-deflector too. I can see merit if you came to a stop and parked the car with roasting hot brakes at the track (where the radiant heat would be huge), but can't imagine the ball joint covers are too affected while on the move with airflow? Either way, yeah, a serious track car should probably have ducting to cool the rotor regardless.
