I've been tracking the Supra since 2009. As an item breaks, I replace it with an upgraded replacement. This is my practice and is agreeable for my wife too. This practice has helped me from feeling as if the car is a money pit as well! I've owned it since 1992 and I'm the second owner. It was a car from Arizona, so no rust when I bought it. It has developed rust-through on the rear fascia (between the tail lights), but no rust anywhere else.
This year the repair plans are to nurse the Dif through five Track Days this season and then rebuild it. The car is still using the OEM sub-frame bush set and they are getting loose, so when VIP rebuilds the Dif, they will replace the bushes with Poly. At that time we might look at lowering the roll center by making the rear sub-frame fit closer to the undercarriage, but that is only a thought at this point. Additionally, this year, we will be replacing the Koyo Rad rather than repair it, as it has been in the car since 2011 and I also replace the elec fans at the same time, so those items are on the short list for February.
In March the car goes in for a once over at VIP Performance in prep for the season. We're adding a boot to the transmission shifter housing so the tranny fluid stays in there rather than on the track and under carriage of the car, and then replace the rear seal on the tranny as well. Upgraded front brake ducting is also added this year along with the beginning of a flat bottom, to include a flat under tray for the engine that extends from the front splitter all the way back to the front sub frame and the spaces on both sides of the undercarriage that extends out from the transmission  and drive line tunnel, out to the side skirts. The engine under tray will be in polycarbonate and the side under trays are in ABS, both black in color.
The car is top heavy and going into some turns at speed is not enjoyable, but rather a lot of work to keep the car on track. We have discussed replacing the front wind screen with PC, but decided rather to cut out the roof and sister in fiberglass, add the six point roll cage with gussets to the B pillar that will stiffen the car and add weight over the rear wheels where it needs it. Lastly, since the engine is getting tired (using oil, loosing compression), in another two years, the engine will need a rebuild. Those are the plans over the next few years.
