Recently purchased this '87 N/A with a dead engine from a friend. They said it had a slight knock.
Current Plans:
Plasti-Dip white for the time being
Black Interior. I will be painting/dying a lot of the parts and using black suede.
7mgte or 2jz swap. (Have a big decision here)
Set up for Auto-X and local twisty roads.
Lots of carbon fiber, though it will be painted
HID Retro-Fit.
Proper Tint
My main issue right now is the Engine. I was planning on rebuilding the N/A and running it while I built a 7mgte. The current engine is more than gone. It sounds like you are pounding a giant metal sheet with a sledge hammer.
I have two engines currently sourced:
A 7mgte that is torn apart and needs put back together. Though it is complete or a 2jzge VVT-i with no throttle body, alternator, or wiring harness. I am trying to decide which route to go down. Price will most likely be the deciding factor.
On to the Pictures:
Came with the car
Questions
Any Idea what these are for? Found them in the trunk:
Also where does this go?
The previous owner told me they kept going bad and to just leave it off, but I believe this may be the cause of the auto locks not working.
The light failure control module was also in the trunk for the same reason, and I think it might be the reason I only get high beams no matter what, and the high beam light in the gauge cluster does not light up.
Current Plans:
HID Retro-Fit.
Proper Tint
On to the Pictures:
Came with the car
Questions
