4U2QUIK;1306616 said:I'm not sure where you're asking for the counterbore to be. But if you mean c-bore the bolt holes, I would need More clearance unless I included SHCS's Which would once again Drive up the price either way.
nope, denied...NTRA08;1309731 said:How about a pic of the inside
IJ.;1309647 said:
SURUKO;1309729 said:#2 is looking nicer ......
Doward;1309798 said:I like #2 as well.
ok... sounds like the 2's have it.GC89;1309878 said:
nah, I'll engrave 7m sux on it instead. j/kDoward;1309880 said:As long as I can still get 7M engraved on the raised portion![]()
5 minutes of production time = $12.50 being added to the final price.upgradedsupra;1309951 said:LOL Drive up price? Dude, it will take less than 5 mins to do that. Counter bore the holes that you attach the housing. Then you can use nice, clean, socket head caps screws and keep everything flush.Yes you would need more clearance but not much and I am sure it will still clear. Just a thought and that's what I would do if I made it.
Duane
4U2QUIK;1310014 said:5 minutes of production time = $12.50 being added to the final price.
Soo ,when it comes to production time 5 minutes is a lot considering the whole part will take between 20-30+ minutes to produce one part on the cnc.
But anyhow, I succumbed to the idea, and if you look closely the new design is counterbored for SHCS.
HKS_TRD;1458212 said:Trying to sell CNC parts can be very trying
I see alot of hatin on the stock water neck and thermostat housing. You can also use the JDM one, which only has 2 instead of 3 fittings on it, and if you use a file, some TLC and some more time ant TLC again, you can make the water neck and thermostat housing look OK, as per below.
I was toying with getting a CNC thermostat cover made here, so I am very interested to see how your second design pans out
