A little wiring progress made today. I got my GM MAP sensor wired in, and a good chunk of the BIC 1zz coil harness hooked up, but since I already cut off the ignitor, I need to ask Randy about a couple wires. I also filled my diff with fluid today.
On a side note, I did replace the spark plugs, PCV valve, and a PCV hose (rock hard and filled 50% with oil and crud on the inside) on my Subaru today.
