hurry up and get that crank pulley on man jeeze. call the fire department and tell them to bring the jaws of life lol
Pardon?honestabe;1638761 said:After I sand down the JB Weld so that it's flush with the edge of my crank the difference in weight will be extremely small. This is exactly what my ATI Super Damper is designed for, to balance the crank
northwestsupra;1638813 said::evil2: dampener ? that is super at its job? although how much out of balance are you going to get when the metal missing is from the front vs the crank weights? and the amount is a pretty small amount that was missing, it looks like alot with that jb weld on it though lol
IJ.;1638814 said:Yep, very little to do with "Balance" on our engines as they're internally balanced
The PMoI is so low that close into the centerline of the crank I doubt you could measure a difference in balance even without the JB Weld in place.
IJ.;1638817 said:Think I would have used a cheesegrater file on it before it had set up fully to get it close to the desired shape as it's going to be a bitch to work when hardened...
IJ.;1638822 said:Nope I'm talking about a Cheesegrater file, commonly used for Bondo and works exactly like a cheesegrater
Personally wouldn't use it for anything other than emergency repairs and never on a thread, that's what Keenserts/Helicoils are for.
